It is currently Tue Jun 16, 2026 3:29 am
PostPosted: Wed Aug 11, 2021 10:01 pm
I installed the Output transformer ( I believe correctly ). When I check for a short between ring and sleeve on the speaker and extension speaker jacks I have continuity. I think this is expected because the 4,8,16 ohms leads and the black lead are all connected and would have to read on my meter as being connected.
Am I overthinking this? In the OSD builder guide we are asked to check for shorting at the speaker and extension jacks... with a plug in and without being plugged in. Won't the ring and sleeve of these two jacks always give a reading of continuity?
I just need confirmation so that I can proceed to the power transformer installation.
Thanks in advanced!
PostPosted: Fri Aug 13, 2021 9:22 am
You'll get continuity through the output transformer as the tip and sleeve are connected to the two sides of it. What you don't want to find is a short to earth I suspect.
PostPosted: Sat Oct 16, 2021 2:16 am
I've been working on a new build and I'm also puzzled by the statement "check the jacks for shorts." At this point - with the impedance switch wired to the OT, what am I checking?
PostPosted: Wed Oct 20, 2021 1:35 am
Does anyone read or participate in this forum anymore?
PostPosted: Sun Jan 02, 2022 9:52 pm
I have the same question about continuity at the same spot as well. Anyone ever find out why? I have continuity against both tip/ring/chassis/transformer outer bell...
PostPosted: Thu Jan 13, 2022 3:19 pm
What Tom_c said.
