It is currently Fri May 08, 2026 4:45 am
 Post subject: New Build, Loud Hum
PostPosted: Sat Nov 20, 2021 8:17 pm
Hi, just finished my OSD build today. Only issue i have is when taking the amp out of standby, i get a loud hum through the speaker, this is without OD or Boost turned on. Would greatly appreciate some help. If i turn on OD the hum gets alot quiter, boost doesnt seem to effect it much. Volumes do kinda effect it. If i turn OD Volume and Master volume off it will go away, but if either is turned on, hum is loud. B4 voltages are a little low at 303 and B5 voltages low at 295
 Post subject: Re: New Build, Loud Hum
PostPosted: Sun Nov 21, 2021 1:53 pm
I got it figured out. I did not run the footswitch ground wire to the ground lug then on to the ground on the board. I had ran it straight to the board. I had assumed the diagram was just a straight line to the board.
PostPosted: Tue Dec 07, 2021 1:54 pm
Happy to hear you found the problem. I find the OSD to be remarkably quiet - even with the OD turned up. It's a great amp.
