It is currently Sat Jun 13, 2026 10:14 pm
 Post subject: HT fuse for Thor kit
PostPosted: Tue Nov 09, 2021 10:26 pm
I just realized my kit only came with a mains fuse. I'm not exactly sure why. What value should I use if I add an HT fuse?
 Post subject: Re: HT fuse for Thor kit
PostPosted: Mon Nov 15, 2021 6:14 pm
Interestingly, most of the 18 watt schematics I've seen do not use a HT fuse. However, I suppose you could use a 0.5A FB between the power supply center tap and ground, similar to the JTM.
Read this from the old 18 watt forum:
https://www.18watt.com/viewtopic.php?p=192209&sid=980af41036e6008bd5744b3a94d096c1#p192209
Here's some good stuff from Merlin (Valve Wizard) on fuses. He opts for 2 fuses on the HT winding prior to the rectifier rather than fusing the center tap:
http://www.valvewizard.co.uk/fuses.html
You could also place safety diodes on the rectifier socket (in series) if you are worried about a short causing PT damage:
https://www.tdpri.com/threads/rectifier ... e3.833572/
PostPosted: Thu Aug 11, 2022 3:38 am
Thank you for sharing PharmRock. Very useful for me
fall guys
PostPosted: Tue Aug 23, 2022 9:40 pm
Thanks, Pharmrock. This is exactly what I need.
LOL Beans
PostPosted: Wed Dec 14, 2022 2:47 am
You're very welcome, PharmRock. Helpful for my purposes greatly.
unblocked gamez
Users browsing this forum: Majestic-12 [Bot] and 4 guests
