It is currently Tue Aug 04, 2026 6:38 am
 Post subject: EH EF86 tube question
PostPosted: Wed Jan 05, 2022 9:19 am
Hi, anyone using it in the TC15? I heard there might be an issue with the glass envelope being too large?
PostPosted: Fri Nov 25, 2022 10:42 am
I have not tried it. On the TC15, the first shield holder can be removed
PostPosted: Mon Mar 03, 2025 3:28 am
i haven't use tht before :shock:
________________________________________________________
doodle jump
PostPosted: Mon Mar 03, 2025 6:00 am
I haven't personally used it in the TC15, but I've heard the same concern about the glass envelope size. You might want to double-check the dimensions against the available space. Some users have mentioned slight modifications or adjustments to make it fit. Hopefully, someone here with firsthand experience can confirm!
Slope
PostPosted: Tue Mar 24, 2026 5:03 am
AnalogOpher wrote:
Hi, anyone using it in the TC15? slope
Yes, some users have reported that the glass envelope of certain tubes may be too large for the TC15, which can lead to fitting issues.
PostPosted: Tue May 12, 2026 4:18 am
Snow Rider
How do I use it?
PostPosted: Tue May 12, 2026 12:26 pm
I am using the EH EF86 in my TC15 and it seems to fit the socket fine and I do like the tone. I don't use the socket holder thing and I can't even recall if that is an issue, but works fine without. It's also been pretty reliable as I've had the same tube in there with weekly use for over five years now. It even survived an unfortunate fall out of the back of my truck!
