It is currently Sat Jul 27, 2024 8:35 am
 Post subject: Faulty cap?
PostPosted: Fri Dec 16, 2022 12:21 pm
Hi there, I’m finally putting my TC15 kit together which has been good fun, my most elaborate build yet. I’m just trying to isolate the issues I’m having so thought I’d ask here:
Im getting buzz from the speaker at all times, everything turned down, no instrument, all channels etc
Channel 1 is loud, volume knob anywhere past 1-2 gets it outside of bedroom volume. Channel 2 is nowhere near as loud, you can crank the knobs and the guitar doesn’t get much louder but the buzzing does get louder.
I’ve gone over the layout a few times and can’t see anything is missing, voltages are all slightly lower than listed on the layout however - about 10% roughly. I’m in the U.K. with 230v if that might make a difference. When I make contact with the turrets to check DC I get sometimes loud pops through the speaker.
Chopsticked everywhere and no wiring seems loose or causes a crackle, I do however get a pop through speaker whenever tapping one of the .01 caps. Could this be a sign of a faulty component? It’s this cap specifically:
I’ve got no replacement on hand and won’t get delivery until the new year to swap it, just trying to understand the circuit but better in the meantime! Of course I could always be barking up the wrong tree
 Post subject: Re: Faulty cap?
PostPosted: Mon Jul 01, 2024 12:12 am
merge fruit
Hello, the slightly lower voltages you're measuring could be due to the difference in mains voltage between the UK (230V) and the voltage assumed in the kit's instructions. However, a 10% difference shouldn't cause significant issues. Just make sure you're not exceeding the maximum voltage ratings of any components.
PostPosted: Sun Jul 21, 2024 11:06 pm
The constant buzz from the speaker, even with everything turned down, could indicate a grounding issue or interference. Since you mentioned that the volume levels on the channels differ significantly, it might be worth checking the gain stages for Channel 2. Regarding the lower voltages, it’s possible that the UK’s 230V supply could affect performance, especially if the circuit is designed for a different voltage. The popping sounds when tapping the .01 caps could indeed suggest a faulty component or a poor connection. If you can, try to visually inspect the solder joints and ensure everything is secure. Since you don’t have a replacement cap yet, maybe you could temporarily bypass it to see if it changes anything? Just a thought! Good luck, and keep us updated on your progress!
papa's games
