It is currently Sun Aug 23, 2026 11:38 pm
 Post subject: Custom plexi FX loop
PostPosted: Fri Aug 08, 2025 9:22 pm
Hi All
I have built the custom plexi and it’s working perfectly.
I’m wanting to add the Trinity FX loop. Does anyone have a layout drawing for it or explanation of how to wire it before I go ahead and blow myself up!!
I have the manual and read it but a diagram for the 18 would be great.
 Post subject: Re: Custom plexi FX loop
PostPosted: Thu Dec 11, 2025 10:56 pm
Philhodson wrote:
Hi All snow rider
The Trinity FX Loop is pretty straightforward to add. The builder’s manual actually has the wiring layout you need — the SEND/RETURN sit between the last preamp stage and the PI, and the board only needs B+, heaters, and ground connected. If you follow the manual’s pad labels, you won’t run into surprises.
If someone has a photo of theirs installed in an 18-watt layout, that would definitely help, but the manual diagram should get you there safely.
PostPosted: Thu May 07, 2026 5:31 am
Thanks. I will dig out the manual again and see how I get on!
PostPosted: Mon Jun 08, 2026 12:16 am
Philhodson wrote:
Hi All
I’m wanting to add the fnf online Trinity FX loop. Does anyone have a layout drawing for it or explanation of how to wire it before I go ahead and blow myself up!!
I’m running EL34s with a standard bias setup, and the voltages look stable when I check them cold. Speakers and cables are fine (tested with another amp).
