It is currently Wed Aug 26, 2026 12:42 pm
 Post subject: Tc-15 help
PostPosted: Sat Dec 06, 2025 8:54 pm
So I am trying to get my old kit working. I have traced down that one of my jumper wires wasn’t sending voltage. It is now working and I am getting correct voltages everywhere except on v5 and v6 I am getting roughly 120v instead of 242 on pin 9. I am wondering if the resistor that I have wired in off the b+ voltage is incorrect. I am getting no sound out of the amp. Some popping and clicking when I turn the contour switch/plug in and unplug the 1/4 in jack. Tubes all heat up. What do you guys think is my issue in my guitar signal wiring and what should I check?
 Post subject: Re: Tc-15 help
PostPosted: Sat Dec 06, 2025 9:28 pm
V1
Pin 1: 81
Pin 3: 1.94
Pin 6: 128
Pin 8: 1.94
V2
Pin 1: 143
Pin 3: 1.29
Pin 6: 144
Pin 8: 1.29
V3
Pin 1: 173
Pin 3: 1.22
Pin 6: 268
Pin 8: 172
V4
Pin 1: 213
Pin 2: 22
Pin 3: 49
Pin 6: 330
Pin 7: 45
Pin 8: 66
V5
Pin 3: 3.63
Pin 7: 383
Pin 9: 117
V6
Pin 3: 3.63
Pin 7: 380
Pin 9: 117
V7
Pin 8: 385
PostPosted: Sat Dec 06, 2025 9:33 pm
I have verified that the resistor that feeds the irregular voltages on v5 & v6 is correct according to documentation.
PostPosted: Thu Jan 22, 2026 11:18 pm
Thanks for posting these detailed voltages. V3 Pin 6 (268V) looks suspiciously high for that stage. To make troubleshooting easier for others, maybe upload a marked-up schematic next time? If you’re hitting file limits, using an image converter to optimize the file size often solves the issue.
