It is currently Tue Aug 25, 2026 10:28 pm
PostPosted: Tue Apr 28, 2026 5:14 am
Hi everyone,
I’ve been using a TRIWATT build for a few weeks now, and I’ve noticed something odd: after about 20–30 minutes of playing, the overall volume drops slightly, and the tone gets a bit dull compared to when the amp is first powered on.
I’m running EL34s with a standard bias setup, and the voltages look stable when I check them cold. Speakers and cables are fine (tested with another amp).
Has anyone experienced a similar “warm-up tone loss” with the TRIWATT? Could this be related to tube drift, a specific component heating up, or something in the power section?
Smash Karts Game
Any ideas on what I should check first would be really helpful.
PostPosted: Tue Jun 16, 2026 6:43 am
Has anyone used the TRIWATT and noticed a similar "warm-up tone loss"? Could this be caused by something in the power section, tube drift, or a particular component heating up? basketball stars
PostPosted: Sun Jul 19, 2026 9:26 am
You can check the bias when the amp is fully warmed up. If the EL34 bias drifts after 20–30 FNF minutes, it could easily cause the volume drop and duller tone.
