It is currently Tue Dec 02, 2025 5:36 pm
 Post subject: sIII Pot Values
PostPosted: Fri Jun 16, 2006 11:52 am
What determines the values of pots. Why use a 500K instead of a 250K or 1M? Planning a sIII next (only need chassis & transformers). I had already acquired pots for the build but used the old layout with the 1M for bass.
Thanks.
Kenny
PostPosted: Wed Jun 21, 2006 3:37 pm
The reason for using different pots is for different ranges of responce. Taking the bass pot as an example, on many amps the bass pot really only responds from 0 - 3 when using a 1M pot. So changing it to a 500k or 250k gives more fine control over the usable range. Depending on how it is wired (to the top of the mid pot or just a variable resitor to the tone cap), it can also change the bass curve of the tone stack.
A great tool to visually see what is going on is the Duncan Tone Stack Calculator which can be found at http://www.duncanamps.com.
Richard Johnson
PostPosted: Sat Jun 24, 2006 9:56 am
Thank you!
PostPosted: Sat Jun 24, 2006 4:57 pm
Yes, thanks Richard! I'm on holidays til July 4th. Just sneaking a peak!
Users browsing this forum: Google [Bot] and 25 guests
