It is currently Tue Apr 08, 2025 3:13 pm
 Post subject: couple simple questions
PostPosted: Fri Sep 22, 2006 10:06 am
I've started a sIII kit and have a couple questions:
1)I have the tube sockets installed as follows, rectifier, outputs, space, space, preamps. Should I put a space between the rectifier and the output tubes, or is it fine next to it? I have the heater wires soldered in already, but I can change it if it will cause problems.
2) I wired the big cap, and guessed that the black rivet on the one lug means ground. Am I right, or will this thing shoot into outerspace when I apply power?
Thanks for your help!
Joseph
PostPosted: Sun Sep 24, 2006 12:46 pm
joseph, Yes, big black lug is ground connection. The latest layout shows recommended slots for the tubes.
viewtopic.php?t=689
PostPosted: Sun Sep 24, 2006 11:01 pm
I was impatient and built before you got a chance to reply. :) I have my three 12ax7s all the way to the side of the chassis. It was tight, but I managed to get the two turret boards mounted on both sides of the far socket. Built it, tested it, and am happy that it is working!!! I noticed the squeel past MV 8 and checked on this forum. I just grounded my output jacks to the chassis, and the squeel is gone! Thanks guys.
PostPosted: Mon Sep 25, 2006 7:26 am
Congrats on the build. Usually we reverse the leads on the Output tranny to get rid of a squeal, but I see you got rid of it by grounding - good work.
Any pics you want to post?
Users browsing this forum: Google [Bot] and 13 guests
