Mods: Marshall mod. on the PI, Cut control from a DC30.
Bright switch with 180pF and 270pF, Tone bypass.
Tested with Eminence 100W 8 ohm Speaker
Electro Harmonix 12ax7, Sovtek EL84
Very low noise level, no hum or other strange sounds, worked perfectly
the first time I plugged it in. Followed the Trinity 15 layout for some parts,
thanks Coco for making the schamtics and layout public on this board.And
for answering my questions.
ok, some measurements:
EL84 Cathode Bias Voltage= 12.47V 150 ohm resistor
EL84 Plate to Ground =357V & 357V
EL84 Screen Voltage= 357.5V & 357.5V
EL84 cathode current= 41.5mA
EL84 screen current = 4.4mA
EL84 plate current = 37.1mA
EL84 plate dissipation = (357-12.47)x37.1mA = 12.78 W
I know its a bit high....
With the master volume at '2' (in a 1-12 scale) this thing is loud..
I'm started to wonder if I had put in the correct 1M A pot for the
master volume, had to check twice
Cut control works like a charm, I find that the amp is not too bright
as it has been reported on other Spitfire builds. Just need to finish that
cabinet now.
Schematic and build photos:
http://home.online.no/~eber-ha/TubeAMP/amp_build/Espen
