It is currently Tue Feb 18, 2025 8:49 pm
PostPosted: Wed May 16, 2007 10:06 pm
Do you have to bias the EL84's on the slll?
PostPosted: Thu May 17, 2007 9:06 am
Nope. Tthe 18, 15 and Deluxe are all cathode biased. No set up required. A common power resistor on the power tubes cathodes sets the bias.
In contrast, a JTM45 does requires biasing making that build more complex.
PostPosted: Mon May 21, 2007 9:08 am
As a side note i have found that you need to keep an eye on your power tubes. The Ampmaker 18 watt lite i built took JJs fine with the 150R cathode resistor but when i tried NOS Polam EL84s, there was a little red-plating under low light conditions. I upped the cathode resistor to 180R and had no further problems.
Simon
PostPosted: Mon May 21, 2007 9:12 am
Or you could have made sure not to use your amp in low-light conditions. :lol:
PostPosted: Mon May 21, 2007 9:13 am
Safe advice. We have used 125 ohm OK so far.
PostPosted: Mon May 21, 2007 2:47 pm
Of course they still red plate in bright light conditions, but tubes always sound great when they are dying! :lol:
So a few minutes of bliss might be worth changing tubes every song! :roll:
Richard Johnson
Users browsing this forum: No registered users and 45 guests
