It is currently Tue Jul 16, 2024 5:26 pm
Post new topic Reply to topic  [ 182 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Mon May 28, 2007 11:54 am
Rephrase the question.
jcny had the right thread. Leemo your thread was developed for the 6V6 /EL-84 tube transfer switch.
What I'm doing is adding a Marshall jack to my chassis. I'll then plug in my footswitch. Neater setup this way.
I have a 4 pin jack. I only have it connected from the 22uf/2k7 turret. Their is a second connection from the 6 pin switch to pin 3 of V2. I imagine that's just for the V6 layout. I'm pretty sure I'm correct, as I'm only switching into the resistor/cap network , which therefore adds the boost in for the sIII. Once I jack in the footswitch , I'll be good to go, well hopefully.
I'll be starting the power up today, so want to make sure all my "t's" are crossed prior to.
Jac
Wait, here's a pic, not great, but it shows the connection.
http://jpritchard.photosite.com/sIII/Picture_004_1.html
PostPosted: Mon May 28, 2007 12:32 pm
Ya know, after studying both the sIII and sIII/V6 schemo I do believe it should be wired to V3 also.
answered my own question. Hopefully :shock: :D
PostPosted: Mon May 28, 2007 12:48 pm
jac wrote:
... here's 4 shots of my electronic room.
Do you use the fan to cools off your amps! :lol:
BTW: The boost is strictly on V2 cathode on an sIII. Try the footswitch but I expect it will pop.
Good luck!
PostPosted: Mon May 28, 2007 1:08 pm
I'm still thinking of adding an air conditioner along with a couple more fans :lol: When I turn everything on, I'm still sweating quite a bit :lol: :lol: I just like to be surrounded by musical equipment. I mean what If I'm in the mood to play well..whatever, I've got it. I still have 3 more rooms of gear :shock: 2 local music stores want what I've got bad. :lol: :lol:
Anyway, so your saying that the switch you developed for the V6, I'll have to build. It was developed for the V6/EL84 switch and the boost.
I'll have to go get the parts then.
Shouldn't effect power up now, right?
PostPosted: Mon May 28, 2007 1:27 pm
No affect on power up. The switch we put inot our builds is not mechanical, it's electronic. Called the "Soft Boost".
PostPosted: Mon May 28, 2007 1:32 pm
Okay :D
On with the power up :D
PostPosted: Mon May 28, 2007 7:22 pm
Okay here's the pre-power pics (not the greatest). The variac is next.
Actually scared :shock: Because of last time.
Hooking up an 8ohm speaker instead of a dummy load this time.
I have changed any little thing. So we'll see.
Also repaired my crybaby. I need this in front of the amp. Some caps blew. On my eye break I did that :D
Think I'll eat 1st :lol: :lol:
Later.
http://jpritchard.photosite.com/powerup/
PostPosted: Mon May 28, 2007 7:40 pm
Food wasn't ready :cry: 15 min.
So I'll get ready, chopstick is next. We'll test every connection.
PostPosted: Mon May 28, 2007 7:47 pm
Good luck Jac, fingers (and toes, and doesn't THAT hurt) crossed :D
PostPosted: Mon May 28, 2007 7:49 pm
Thanks, still haven't started :lol:
PostPosted: Mon May 28, 2007 8:03 pm
You got me thinking about if I should be looking for mushroom clouds to my southwest when it came to me.
In Back to the Future when Marty was in front of the wall of sound, since it was the 50's - - - - NUCLEAR POWED TUBE AMPS :shock: :shock: :shock:
How 50's, nuclear powered cars, nuclear harbor dredging, so nuclear powered tube amps, tubes big as 55 gallon drums :twisted: :twisted:
OK, so my mind works weird!
PostPosted: Mon May 28, 2007 8:19 pm
Okay I'm fed. Where's the beer! Damn heat wave, with all the fans (see Coco, the fans are on in preparation for the start up) on, I had to put a doo rag on to get the hair out of my face
But it's so fun :D :D I love that movie just because of the amp. AND you can build that. Not that I would want to be in front of it :lol: :lol:
Still stalling,
Hey jcny, I bought a new book, it's great.
I purchased Kevin O'conners "DIY Speakers Cabinets" $15.00 and well worth it. I've been building cabs since I was 10. I'm only thru half the book and learned a ton of info.
PostPosted: Mon May 28, 2007 8:33 pm
Okay, the variac is ON. YEA :lol:
Guess it's time to go back to the book and read as I power up.
I LOVE guitar amps :D :D :D
PostPosted: Mon May 28, 2007 8:50 pm
Well, 50 volts.
This is where I was the last time. Readings are okay so far.25% of what is expected for the amp
PostPosted: Mon May 28, 2007 9:22 pm
80 volts, tranny's cool to touch. We'll see
PostPosted: Tue May 29, 2007 6:17 am
Funny, after I got the voltage up to 115, I left her on for another 15 min then shut her down for the night. Why? I don't know. I'll start taking readings now.
On another note though, She's WORKING and GLOWING beautiful. Yea, I've got an 18 watt sIII.
PostPosted: Tue May 29, 2007 6:34 am
More Details please!
PostPosted: Tue May 29, 2007 6:41 am
Ha ha, It's about time, eh
She's on now, I'll start the readings now in comparison to your charts. I'll be using the beefy tubes 1st. Sovtek 12AX7WA's and OTK41's (Russian military EL84M's. I don't trust anything yet :D
The worst part is waiting to plug in. I can't wait to try the 3335 :D :D
PostPosted: Tue May 29, 2007 6:58 am
Okay, I cheated. Glad I did thou.
I have the normal channel playing. But I have no sIII channel. Completely dead.
Also had it dimed on the normal and it wasn't that load.
Maybe the cable?
PostPosted: Tue May 29, 2007 7:11 am
Maybe the cable?
Congrats. Having sound on the Normal channel is a good thing. Means the PI & power is working and you can focus on V2/ sIII channel.
Do check the sIII shannel input wiring tho! This is a combo. Did I send you a combo input jack wiring pic?
Write down your voltages and it's time to pull out the troubleshooting manual. Seriously, give the manual a read and see if you can pick up a few tips.
