It is currently Tue Jul 16, 2024 4:36 pm
Post new topic Reply to topic  [ 182 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Tue May 29, 2007 7:16 am
PostPosted: Tue May 29, 2007 7:17 am
I'm reading it right now. I'm havibg a hard time putting the V2, V3 tubes in. I mean a hrd time. Holes are open. So I'm just reading 1st.
I live the fact that there's sound. Very exciting.
PostPosted: Tue May 29, 2007 7:18 am
didn't come thru
PostPosted: Tue May 29, 2007 7:22 am
Hey, I didn't do it that way :? :? . Guess time to re-wire, damn :roll:
PostPosted: Tue May 29, 2007 7:29 am
Printing now, The jacks are out, I definitely did not wire this way.Now I got it,Wierd thou.
The sIII channel is wired corectly. However the normal channel is wired wrong :? Rewire and see.
PostPosted: Tue May 29, 2007 9:07 am
I would have guessed the opposite. sIII wrong / norm correct. but hey.
PostPosted: Tue May 29, 2007 9:31 am
Okay, rewired the normal channel. The sIII input was wired correctly. Don't understand how I accomplished that one
Also opened up the tube sockets. They're working better now.
See what happens.
Yea, ya got me :? :? :? Don't know why the reverse
PostPosted: Tue May 29, 2007 9:39 am
Now I've got no sound.
When I dime the sIII channel on both the master and volume I'm getting a popping constant intervals. Oscillating?
PostPosted: Tue May 29, 2007 9:41 am
Wonder if I should just install new lengths of shielded cable?
Also, Either before or after I got no hum at all on all jacks when touching it with my finger or metal
PostPosted: Tue May 29, 2007 10:45 am
doubt it. do you get a noise when you tap the input pins on V1 with a small screwdriver? (be careful)
PostPosted: Tue May 29, 2007 1:07 pm
I got the "small noise" when I used the meter probe against them, so yes
PostPosted: Tue May 29, 2007 6:32 pm
Screw it, I'm going to go to the original build and schemo, I'll change everything(well, not everything, lol). This will play today :twisted:
Here's the last pics I took:
http://jpritchard.photosite.com/powerup/
PostPosted: Tue May 29, 2007 7:46 pm
Are the voltages OK? Before you change too much [too many variables and you did have sound] lets start with that. See if they're in range. Then we move on to the signal path. Starting with getting the Normal channel to work. One thing at a time.
I suggest a ground continuity check.
Getting a 'pop' is a good thing. You're not that far away.
PostPosted: Tue May 29, 2007 10:48 pm
As I'm redoing everything, I found a major problem.
One of the turrets moves. Now as long as I solder from end to end it'll be fine, but I'm pissed, so I just might build a new one.I don't know.
PostPosted: Tue May 29, 2007 11:03 pm
jac,
The "Normal" channel was working before. Then, you made it look like the TMB channel. Now neither work. Sounds like you've miswired both, now. :? This is a very common mistake. I've seen it in probably half of the builds where the plastic "Marshall style" jacks are used. Look very closely at them. My guess is that they have you confused a bit. I took one before installing it and plugged a short cord into it , then broke out the ohm meter and "figgered" it out. Then when I looked at the diagram it made perfect sense. Either that or I guessed in the 50% that were right. Flip a coin. :lol:
LeeMo
PostPosted: Tue May 29, 2007 11:05 pm
The way I'm going I'll have redone this 3 times.
So everyone knows, since alot of newbies are now on this site, this has nothing to do with Trinity. I've had medical problems that have resulted in severe brain memory loss. Because of this well.... I screwed up alot of everything.
Do not want any blame to go to anyone but myself.
This is why this poor amp and me are having our problems. Sucks
Peace,
Later,
Jac
PostPosted: Tue May 29, 2007 11:08 pm
Thanks, Leemo, I'm just going to rebuild, I'm at the screw it stage again and trying to get out of it. Taking a break right now and back I go. Whatever.
Thanks for the reply
Later
PostPosted: Tue May 29, 2007 11:09 pm
I just looked at mine and I wired both sets like the Normal channel with both facing the same direction.
LeeMo
PostPosted: Wed May 30, 2007 7:53 pm
think I found the problem, little soldering , I'll get back to ya.
I also bought an alligator clip for the meter. Maybe now I can actually read my meter
Later
PostPosted: Wed May 30, 2007 9:40 pm
forgot how much "fun" the jacks are. 1st one done (had to build a rangemaster in the stead) on to the 2nd. amp will be done sooner or later
The jacks were definitely screwed up.
Later
Jac
Users browsing this forum: Google [Bot] and 17 guests
