It is currently Tue Jul 16, 2024 4:10 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 09, 2007 9:13 am
I have tried another tube on V3 position( i pulled it from v1 and v2).
Which tone cap do you mean exactly?
PostPosted: Sat Jun 09, 2007 10:26 am
Is the problem in the TMB channel only? If so, could be the 500 pf cap.
PostPosted: Sat Jun 09, 2007 10:38 am
I replaced it and it the noise is the same.
It does not depend on the volume so I can not tell if it comes only from TMB channel.
It only stops when I pull the V3 and if the standbay isnt on.
When I turn the heater on I can sometimes hear(it is very faint) the noise without standbay switched on.
PostPosted: Sat Jun 09, 2007 11:54 am
Have you've tried a different tube in V3?
PostPosted: Sat Jun 09, 2007 12:03 pm
Yes I swaped V3 and V1 tube, because I dont have spare ones at home.
PostPosted: Sat Jun 09, 2007 12:44 pm
You need to find out if it's the tube...
Pull v1; does the amp still 'motorboat'?
if yes,
swap v1 for v3; does the amp still 'motorboat'
PostPosted: Sat Jun 09, 2007 12:58 pm
It motorboats until i remove V3.
When I swap V3 and V1 it still motorboats.
PostPosted: Sat Jun 09, 2007 1:50 pm
Well it sounds like it's not tubes. Check to see if a ground wire came loose, or a connection to the tubes or of the board or even the input jacks.
You need to confirm if its both channels or not and if Hi or Lo. Just plug your guitar in and test each one. If it's common to both channels you'll have to check all the parts/connections. If it's only on one channel, then you can eliminate some parts.
Poke at some of the connections with the chopstick to see if you can make it happen or hear a problem.
Have the voltages changed since you built it or not?
PostPosted: Sat Jun 09, 2007 4:18 pm
I tested it with guitar and I do not hear anything except some breaking intervals when I hear distorted sound, on the TMB I dont hear a very little amount of guitar sound and on the normal chanel is very distorded pretty much continious sound.
PostPosted: Mon Jun 11, 2007 12:18 pm
I replaced the B+ caps(16uf ones) and it still motorboats, what could be cause this?
PostPosted: Wed Jun 13, 2007 2:32 am
It works, it looks like that some wires were picking the noise, now it is quiet as night.
PostPosted: Wed Jun 13, 2007 7:18 am
Which ones were the problem? That was a nasty sound.
PostPosted: Wed Jun 13, 2007 9:16 am
I do not know, I just sticked the chopstick and pulled 3 wires that goes to V3 away from the heaters and it stopped. I moved them before but nothing happened.
It looks like that you have to using force on electronic devices works the best. :)
I took it to school today and the profesors were WOW and my school mates.
One of them tried it and it said that was very good. :P
