It is currently Tue Jul 16, 2024 1:51 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Jun 10, 2007 4:28 pm
G-log wrote:
Dude!!! [rubbing hands together] so ..you make cabinets?!!
Stew
Yeah I have made a few .Will post my rig when it is done![/quote]
Would you be into making a few $$ on the side? Nothing complicared.
Stew
PostPosted: Sun Jun 10, 2007 4:31 pm
Well ,first test done-no smoke,2 curious voltages tho...pin 4-yellow wire- on the rectifier socket(no tube installed)says 3.68VAC pin 5- white wire -says 8.05VAC.Any ideas?other readings normal..
PostPosted: Sun Jun 10, 2007 4:57 pm
For those filament voltage checks, I think you need to measure from pin 4 to pin 5 not referenced to ground.
Stew
PostPosted: Sun Jun 10, 2007 5:06 pm
There should be 6-7 Volts AC across pins 4 & 5. Without the rectifier, little to no on pin 3.
PostPosted: Mon Jun 11, 2007 12:44 am
Ahhhh. I see--6.66VAC ! looks good for rectumfrier tube test as soon as it arrives.Thanks guys!
PostPosted: Mon Jun 11, 2007 1:32 pm
IT"S ALIVE--IT"S ALIVE !! Got my rectifier tube in the mail this AM .Put it in ,did the tests-tubes in -Presto-Rock-o-rama!!Everything is working great ,no hum issues.Best of all it sounds Awesome.Can't wait to crank it up with the crew.Next step ,try all my preamp tubes for the best combo....Hmmm -I wonder which kit will be next!Thanx Coco -bitchin kit man!
PostPosted: Mon Jun 11, 2007 3:58 pm
Ahh, that's what makes it all worthwhile!!! Specially the bitchin' part !!! :D
PostPosted: Mon Jun 11, 2007 4:11 pm
The bitchin' part is the best. Only the best of the best parts for Coco's kits. Sweet :D :D :D
PostPosted: Mon Jun 11, 2007 4:16 pm
Hey Coco,
Looking at the pics again, is there a way to enlarge them :?:
I'd really like to see the pics up close and personal.
PostPosted: Mon Jun 11, 2007 4:22 pm
Do you mean my pics Jac? I can repost them larger if you like.
PostPosted: Mon Jun 11, 2007 4:26 pm
Yes, I still have a ground fault. Since yours sIII is working now I'd ;like to compare. This way I'll make sure the top is identical 2 yours. Looks like I'm going to have to take the board back off. That's a bitch job. I'm still hoping it's on the top.
Be nice to check against yours.
Also be nice to finish, because the TC's coming. :lol:
sorry, been dying for this amp :lol:
So please and thank you in advance
PostPosted: Mon Jun 11, 2007 4:44 pm
I reposted them a bit larger,but I can't seem to get them any bigger.Pm me if you want & I can try to help.G.
PostPosted: Mon Jun 11, 2007 5:57 pm
Sorry, I don't know how to PM :oops:
My email is : jerryrigstudio@gmamail.com
Thank you
PostPosted: Tue Jun 12, 2007 7:30 am
jac, to PM, press the PM button beside a members name. It sends a Private Message.
PostPosted: Tue Jun 12, 2007 4:47 pm
Day 2 -amp still rockin' .I installed the boost mod today,Definitely recommended ! I'm using a Radial JX-2 switcher for a 2 channel setup .Thios is sooo much fun!
PostPosted: Tue Jun 12, 2007 7:14 pm
What's this ?
A Footswitch?
PostPosted: Tue Jun 12, 2007 9:50 pm
Radial Switchbone ABY switcher with a tuner out and mid/gain boost.
PostPosted: Tue Jun 12, 2007 11:37 pm
Thanks for the pics Gary. Very clean and clear., Coco you should have these.
Still don't get it. Is it a footswitch? Wouldn't happen to have a pic :D :D
PostPosted: Tue Jun 12, 2007 11:57 pm
ImageHere's a pic bro!
PostPosted: Thu Jun 21, 2007 6:55 pm
Here are some pics of the rig! ImageVintage gold/black sparkle vinyl.Speakers are Celestion blue dogs &G12H heritage-1 in each cab
