It is currently Tue Jul 16, 2024 4:11 pm
PostPosted: Sun Jun 17, 2007 9:04 pm
I built a 18 watt TMB. I was posting at 18 watt for a while. I got ALOT help from a guy named Phil over there. I've forged ahead on my own, but now I have a few questions. I know the site is coming back up, but I'm really close and would like to wrap this thing up.
My voltages are way off from a voltage chart I saw on 18 watt. I assume that chart is for an 18 watt (not TMB). My voltages are more inline with what I have seen on this site. My V2 voltages seem a little low though and I have a question about my V4/5 voltages and the wattage I calculated it to be dissapating.
The schematic I used is quite similar to the one here. I deviated from it in that I used a 1000uf cap on the V4/5 cathode bypass cap, it's one channel/one input (the TMB), 22uf cathode bypass cap on V1 instead of 1uf and V1 in parrallel with itself.
V2 voltages:
1 - 144
3 - .97
6 - 258
8 - 142.1
I checked V2 plate resistor and it measured 97.8 K whcih is well within 5% and if anything would make the voltage higher as opposed to lower.
I think my V 4/5 voltages are close to what I see here, but when I figure plate dissapation it's over 20, which can't be good. Hopefully my calculations are wrong.
V 4 voltages:
3 - 12.12
7 - 328
9 - 318
V 5 voltages:
3 - 12.12
7 - 329
9 - 316
B+ 345
Does anyone see anything here that's worth worrying about? I love this amp. I've finally got some decent volume and the response is incredible.
PostPosted: Sun Jun 17, 2007 10:58 pm
Things look pretty good there. Is the cathode resistor getting hot? You should have a 5W in there and it shouldnt get too hot at all.
To check the bias current in a cathode biased amplifier, measure the voltage across the cathode resistor and divide by the resistance value to obtain the cathode current. Since the two output tubes share a common cathode resistor, you must divide the current reading by 2 to get the bias current.
Calculate the wattage by (Cathode Current )^2 X Cathode Resistor
I^2 X R
PostPosted: Sun Jun 17, 2007 11:26 pm
Thats what I wanted to hear about the voltages . Thanks a bunch coco.
I just read an article on aikenamps that said the same thing about a common cathode resistor. I was actually wondering about that as I posted, which prompted me to google calculating dissapation.
Nothing seems to be getting hot. I also figured if I were dissapating 20 watts per tube I would have noticed the tubes glowing some interesting shades. I'm actually running 10.21 per tube.
PostPosted: Mon Jun 18, 2007 6:50 pm
That's a source of a lot of good information!
