It is currently Sat Apr 12, 2025 5:25 am
 Post subject: 5w lightning
PostPosted: Thu Jul 05, 2007 1:41 pm
Has anyone designed a lightning power section with just one el84? What would that look like? :)
rick...
rom. 5:8
PostPosted: Thu Jul 05, 2007 5:08 pm
We've been currently discussing these. the Single-ended amps. Lets see the thread is :
viewtopic.php?t=948&start=0&postdays=0&postorder=asc&highlight=
check it out.
Later,
Jac
PostPosted: Thu Jul 05, 2007 6:45 pm
thanks Jac,
I was thinking of something like a 2nd channel on a vjr or putting the channels from a tc-15 in front of a vjr power amp. Am i out in left field or is that even possible?
thanks
rick...
rom. 5:8
 Post subject: Re: 5w lightning
PostPosted: Thu Jul 05, 2007 6:53 pm
That would be like an AC4 with the lightning front end. Quite doable. I have thought about that actually. Just need some play time!
PostPosted: Thu Jul 05, 2007 10:40 pm
It's a rough job Coco, but start playing. I'd like an AC-4 :D :D :D
PostPosted: Fri Jul 06, 2007 2:38 am
That would be most excellent...
 Post subject: tc-15 schematic...
PostPosted: Fri Jul 06, 2007 10:50 am
I am new to amp building and i'm trying to understand this stuff. On the tc-15 schematic, is v3 the pi? It looks like each channel goes into a different side of v3 and is fed to opposite tubes in the power amp. Help me understand the flow.
thanks
rick...
rom. 5:8
PostPosted: Fri Jul 06, 2007 12:06 pm
Hey Rick
I know how you feel. Thankfully I think I've learned a lot in the past few months about circuits. V3 is the PI, but I can't tell you about the flow.
PostPosted: Fri Jul 06, 2007 1:24 pm
Hi Guys, I'm building the TC right now :D I do believe V4 is the PI. , because the EF86 is V1. Take alook at the PI circuitry. It flows towards V4, not V3.
Can't wait till I'm done. This is TC-15 # 2. :D Going to be great,.
Later
 Post subject: confused...
PostPosted: Fri Jul 06, 2007 1:45 pm
Later
jac,
are we looking at the same schematic? tc-15-7Jun07? i see the ef86 as v7 and v4 is one of the el84s. I probably don't have the right schematic.
rick...
rom. 5:8
PostPosted: Fri Jul 06, 2007 3:07 pm
Right. Jac's looking at the tube layout from side to side. The only reason I didn't say V4 was because I checked out that schem. The phase inverter on the schem is where the 47K, 1M, 1.2k, and 1M resistors meet to make a cross.
 Post subject: cool
PostPosted: Fri Jul 06, 2007 3:22 pm
thanks JamesO,
where does the preamp end and the poweramp start? :?
sorry to have so many beginner questions and thanks for everyones patience with me.
rick...
rom. 5:8
PostPosted: Fri Jul 06, 2007 3:25 pm
Your looking at the right schemo, but your reading it backwards. The layout or schemo has the tubes at the bottom. V1 is the EF86. Looking at it from that angle you'll see the difference :D
Got it?
 Post subject: finally
PostPosted: Fri Jul 06, 2007 3:55 pm
Got it?
yup, i'm trackin' now...
rick...
rom. 5:8
PostPosted: Fri Jul 06, 2007 6:26 pm
Jac, he's actually reading it right. The schem (at least the one available right now in the TC-15 docs) lists the EF86 as V7. A little strange, but it's what the schem lists it as.
Rick, I'm going to a wedding rehearsal right now, but I'll identify what I can when I come back later this evening. But if anyone else wants to, go for it!
 Post subject: which models are which?
PostPosted: Sun Jul 08, 2007 2:37 pm
Is the TC-15 the dual channel w/ef86 and the Trinity 15 the single channel original?
thanks
rick...
rom. 5:8
 Post subject: question about v1 & 2
PostPosted: Sun Jul 08, 2007 11:36 pm
On the TC-15 Schematic, is v2 wired as cascade gain stage? It would be v3 on the layout. And how is v1 (schematic), v2(layout) wired? Sorry if the question is hard to understand.
thanks
rick...
rom. 5:8
PostPosted: Mon Jul 09, 2007 4:20 pm
Hey man
You're correct about the TC-15 and Trinity 15 differences. I don't understand the second question. Sorry I never got back about the signal flow of the amp.
PostPosted: Mon Jul 09, 2007 7:50 pm
bsmco wrote:
Is the TC-15 the dual channel w/ef86 and the Trinity 15 the single channel original? thanks :?:
Yes, the Trinity15 is the original Trinity 15. TheEF-86 channel is very close to the AC15 [specially with the correct contour setting :wink: ]
PostPosted: Fri Jul 13, 2007 9:13 pm
i'd love to see a lightning 5w. i'm looking to do a new low watt build soon, since my 18w is overkill for my bedroom playing in my apartment. :lol: i'm getting frustrated, i can't ever play the amp at a decent toneful volume.
