Never compared the two because I never built a Spit. The OD is not fizzy on the TC-15 but maybe put a MV pull switch to disengage the MV when you dont need it. The cut helps a lot to control the high top end.
Try defeating the MV on the Spit & see if it's still fizzy.
You can get a board from us of build one from the layout we posted. You can use the same West Labs iron.
_________________ Stephen Web: www.trinityamps.com. Facebook: facebook.com/trinityamps. Twitter: @trinityamps
