It is currently Thu Dec 04, 2025 1:02 pm
PostPosted: Sun Jan 13, 2008 8:30 pm
A friend of mine found this amp sitting by the roadside on garbage day. Its a 1961 Epiphone EA-35T Devon Tremolo, which I understand is identical to the same year Gibson GA-8T.
Overall its in good condition (the tolex is near mint once I cleaned all the dust and nicotine off it) and the grill is also in great shape. The crome control panel is pitted and some of the lettering is worn off, and unfortunately it is missing the back panel and foot switch. So far I have torn it apart and cleaned it and will put new filter caps in it (I need to replace that big one as its leaking!) and of course a 3-prong plug. Check out the pics! :D
PostPosted: Tue Jan 15, 2008 1:02 am
Extremely cool. You have good garbage!!
PostPosted: Tue Jan 15, 2008 11:01 pm
Can't wait to get those caps changed and try it out!!! :D
PostPosted: Wed Jan 16, 2008 12:20 am
I'll bet. I'll see if I can check this out in the reference library!
Hmm, doesnt look the same. My schematic has 2 6EU7, 2 6BQ5 & 1 6CA4 recto. What'sthe tube line up .
BTW, not close to a Gibson Gibson GA-8 FWIW.
PostPosted: Wed Jan 16, 2008 6:03 pm
The tube line up is: 1x 12AX7, 2x 6BM8 & 1x 5Y3
It is the same as the very first GA-8T Discoverer Tremolo.
Check out this link for a little blurb on it:
http://www.drtube.com/guitamp.htm#Gibson
And here is the link to the schematic:
http://www.drtube.com/schematics/gibson/ga-8t.gif
PostPosted: Wed Jan 16, 2008 7:57 pm
Who would have thought there would be such a difference with just the letter T. Glad you discivered the info too.
Interesting to hear how it sounds.
PostPosted: Fri Jan 18, 2008 6:48 pm
When I get it fixed up I will try to get some sound clips to share. I'm curious to hear it too!
PostPosted: Sun Jan 20, 2008 6:42 pm
So I was searching the net for capcitors.... the one cap is a 20 MF @ 25 VDC.... no problem, I have some 33 MF @ 35 V I will use for that one - I used those to replace the 25 @ 25s in my 2 Supers and they worked great! But the problem looks like that big cap, which is 3 in 1.
It is actually a 20, 10, 10 @ 450 V. I couldn't find anything like it online at the Tubestore, turretboards.com, BBQ, Mojo, etc. The closest I found was a 4 in 1 cap that was 40, 20, 20, 20 and another that was 4 x 20. It shouldn't be a big deal to go with something like that unless anyone else knows where I can find a 20, 10, 10. If the paper tube for the original cap was in better shape I would just hollow it out and put 3 caps inside it and keep the original look. Any other suggestions?
PostPosted: Sun Jan 20, 2008 8:52 pm
Yes, CE Manufactured FP type can cap. CEDist part number C-EC20-10-10-10 is a 20-10-10-10 @450 multi-section cap. Try Antique Electronics, their retail arm, or you could just replace with individual caps.
PostPosted: Mon Jan 21, 2008 6:29 pm
I forgot about Antique Electronics... that cap looks like it would be a little better because its smaller then the 40-20-20-20 I mentioned in my last post. Thanks for the tip Stephen! :D
PostPosted: Tue Feb 12, 2008 6:34 pm
I ended up replacing the cap can with individual caps, as my dad had the ones I needed in his parts stash. All new electrolytics and wired up a spare switch I had sitting around for the tremolo, put it all back together and man does this amp sound sweet!
At around half volume, its got a great slightly distorted tone (almost a bit tweed-ish with a bit more bite) or you can crank it to full volume and get a little more dirt. The tremolo sounds great too. Will get up a couple more pics soon as well as a sound clip or two if you're interested! :D
PostPosted: Wed Feb 13, 2008 7:44 am
Congrats on the restoration. Looking forward to more pics.
PostPosted: Sat Apr 05, 2008 4:25 am
I love amps. I have so many that need to relive.
Congrats on the Devon. I had one. Nice jam.
Later
PostPosted: Mon Apr 07, 2008 11:49 pm
I still have to get around to recording some clips of this amp. I love it. I've been playing it more then any of my other amps. And while I've never been into using a lot of tremolo, I use it a lot on this amp cause its one of the nicest sounding tremolo I've heard. This amp sounds great at clean volume levels, or at full out to get some good crunch. I love it! Also sounds great no matter what guitar I plug into it.... Strat, Tele, Les Paul, PRS, Jaguar, they all sound great! :D
I have put a new speaker in it tho... the original has started rattling every time I play an A. It now has a 30 watt BBQ vintage style alnico (equivalent to a P12Q I think it is?). It sounds even better with this new speaker as it gives it a little more volume, and a bit more power in the lows and mids.
PostPosted: Thu Apr 10, 2008 10:07 am
That's a great story. I love happy endings.
