rivritt wrote:
So there are lots of people talking about modding their Ceri@tone TMB's with the cascade mod. Is this different from using a jumper?
If you are referring to jumping channels, it is very different. Can you post the schematic?
It would seem overkill to do it on a TMB tho as it gots plenty of overdrive. But for an sIII or our Plexi, it makes sense. Check out rgtr's post on the sIII One. He did channel cascading with an optical switch but there are other ways of doing it.
rivritt wrote:
Is this something one can do with a Trinity plexi?
You bet!
rivritt wrote:
What exactly does the boost switch do?
Increases the drive/gain on V2 so it adds more volume & distortion. More like a lead switch. You can footswith it too if you follow a previous post in this.
rivritt wrote:
And finally, to get closest to a 12000 series plexi sound in an 18watt, is this the right trinity model to start tweaking with?
I'd say it's a good start. The Trinity Plexi has all the same coupling caps as the Plexi lead and the normal channel is coupled & bypassed the same as well.
