OK, today I'm done with the Lightning for a while. I'm going to use it and see how it goes. There are some things I may or may not do...here we go.
First picture shows how I mounted the trannies. I ordered a #2 chassis from Nik at Ceri@tone, but he shipped me a #1. There's no way I was sending it back so I ended up mounting the power tranny at right angles to the normal setup. In order to put it the normal way, I would have to fabricate a plate.
[/img]
Inside, you see I kinda left the PT wiring sloppy. I may change it, but the amp is quiet as a mouse until the I turn the volume up above 3/4 with the master on full. Then there is a hum. Again, I'll try it for a while.
Detail of wiring for cut control. Since it goes across the PI just like the Master I just jumped to it.
The Master is not very progressive, its action is in the first 1/3 of the turn. I think Matchless must have picked 1M to make sure it's completely out of the circuit when on full. I may go to a 250KA with a switch to take it out of the circuit when not being used.
The Trinity cab is gorgeous, but the top rear panel hits the chassis hard. I'm going to move it down.
Panels are just HP color prints, laminated at Office Max for $2. Of course putting the names of the controls on the bottom makes them invisible when standing. Oh well.
Amp sounds pretty great in the house (but it's fiercely loud!!!). I'm going to take it out Thursday to see what it does in a band situation.
P.
