Thanks for the help,
it's got a red turret board. The amp makes noise when i touch some of the pin with my multimeter. is it safe to plug a guitar in to test?
Here is what i have found.
I have check the resistor values feeding the pins and they are as per documentation.
i have looked at cathode pins 3 + 8 and they all look good too. Here it the break down of what i found.
v2 pin6 reads 256 it should be 197 goes to the board with a 22k resistor and a 22uf cap and the pin bridges to pin 1 with a 100k
v2 pin 3 links to 8 and then to board 1k5 resistor and 25uf cap
v2 pin 3 splits one to the boost switch and to the 225uf cap and the other to the board 1k5 resistor.
v3 pin 1 reads 241 should be 190 connected to board with 100k resitor and a 0.22uf cap
v3 Pin 3 + 8 are linked then to 1k2 on board
v4 and v5 pin 7 reads 385 should be 298. pins are linked and then travel to the crunch much switch and then to OT
v5+5 pin 3 are link and then to board with a 120/5w resistor and a 22uf cap.
I also measured the voltage points on the board, from left to right. I have bolded the stuff that seams out of the usual tolerances.
8 (7.5) 245 (252) 250 (240) 69 (70) 268 (280) 169 (167) 2 (1.3) 120 (145) 2 (1.2) 2 (1.9)
The right vertical side of the board. 60 (80) 341 (200) 107 (120). The resistors are correct values i have attached a photo of my
layout with these reading written on there and a photo of the board build.
