It is currently Sat Dec 13, 2025 11:37 am
 Post subject: EF86 Spitfire
PostPosted: Fri May 26, 2006 10:16 pm
Hi - I'm interested in Spitfire variant with an EF86 in place of a 12AX7. Was wondering whether anyone has built an amp with a like or similar topology?
Thanks in advance.
PostPosted: Sat May 27, 2006 4:57 am
IOW, an AC15 without the Vib/Trem channel?
 Post subject: Re: EF86 Spitfire
PostPosted: Sat May 27, 2006 8:04 am
[quote="gregarious"]Spitfire variant with an EF86 in place of a 12AX7. [quote] could be a modified AC-15 as Mr. Db noted. You could take the DC30 channel and use that as the front end V1 topology.
PostPosted: Mon May 29, 2006 4:46 am
Yep, just volume, tone, MV.
I'm thinking of using a ss rectifier and would like to know what the consensus is versus a tube rectifier, any audible/appreciable difference?
PostPosted: Mon May 29, 2006 7:04 am
SS=Bright & Tight! Little if any compression, but you can try to simulate with a loading reisistor. e.g. a 200 ohm, 5W in series after the rectifiers.
Users browsing this forum: No registered users and 43 guests
