It is currently Fri Apr 24, 2026 12:57 am
 Post subject: Tweed Rectifier Wiring
PostPosted: Wed Apr 29, 2020 11:56 am
I am having some trouble interpreting what I read on the drawing in regards to the rectifier socket wiring. There are two yellows with different readings attached (0VAC & 5VAC) and I can’t tell on from another. The reds are the same so good to go but the yellows have me stumped. What obvious thing am I missing? Thx.
PostPosted: Wed Apr 29, 2020 1:30 pm
Hi Dave, welcome to the forum.
The text and colors on the layout drawing show what colors relate to the various windings on the transformer. The yellows are the 5 volt winding to heat the rectifier. The reds are the high voltage winding with a red-yellow for the center tap that splits the winding in half. It's all AC coming out of the transformer, so it doesn't matter which yellow or red wires you connect to their respective terminals on the socket. Just don't connect a red wire where a yellow one should go! And make sure you connect the red-yellow to ground.
Same with the green and green-yellow wires on the 6.3 volt winding to heat the other tubes.
PostPosted: Wed Apr 29, 2020 6:36 pm
The text and colors on the layout drawing show what colors relate to the various windings on the transformer. The yellows are the 5 volt winding to heat the rectifier.shuttle Paris The reds are the high voltage winding with a red-yellow for the center tap that splits the winding in half. It's all AC coming out of the transformer, so it doesn't matter which yellow or red wires you connect to their respective terminals on the socket. Just don't connect a red wire where a yellow one should go! And make sure you connect the red-yellow to ground.
Hi, thank you very much for explanation
PostPosted: Wed Apr 29, 2020 7:43 pm
Thanks a lot. Turns out you CAN piece it together if you re-read and re-read. I just tripped over some voltages on the lay out diagram. After you responded it all came together. Thx again.
