It is currently Tue Mar 31, 2026 2:16 pm
PostPosted: Mon Feb 28, 2011 2:30 pm
Well folks, It's been about 3+ weeks since I started my first guitar amp build, and I thought I would post some pics. I got alot of help from the good people here, and also from the posts with pictures and descriptions of builds. So, maybe someone else attempting a Deluxe build might benefit from my experience.
1st up - The finished amp and chassis: I used clear 3/4 inch pine for the top and sides, 12mm Baltic birch for the baffle board and 5mm Baltic birch for the back panels. I purchased the wood from The Wood Source:http://www.wood-source.com/about_us/index.shtml here in Ottawa. The tweed, grill cloth, Jenson speaker, the handle and feet I purchased from Mojo. I used a water based contact cement for the tweed that worked terrific. 2 coats of Bullseye amber shellac finished it off nicely.
Here's the open back:
Now the Board and separate components:
The VRM- This was the 1st component I soldered, and didn't have any issues with it.
Here's some pics of the rest of the chassis part by part:
Standby and fuse:
Rectifier:
Power tubes:
Output jacks:
Preamp tubes: Doing my last check before powering up I noticed I had forgotten to tie pins 4 and 5 of the pre-amp tubes together.
Input jacks:
Volume and Tone Pots:
What a blast when I powered this thing up and it worked! All's I can say is it's a great feeling to have an amp that sounds so Creamy and with so many different tones (it'll take some playing around to figure this thing out) and to know that I put the time and research in to put it together. But, I couldn't have done it without the help of the good people on this forum!
Stephen, thanx so much for putting together the instructions which made it fairly easy even for a layman like me, and a
quality product. Now I can put the tools away and get back to makin' music.
Cheers
Clay
PostPosted: Mon Feb 28, 2011 3:34 pm
I'll see if I can get higher res photos up for my last post.
Clay
DONE!
PostPosted: Mon Feb 28, 2011 6:31 pm
Amp looks great! Nice work on the cabinet too! You'll love playing this amp. I finished mine about 2 months ago and I'm still discovering new sounds.
PostPosted: Tue Mar 01, 2011 11:21 am
Thanx Case24, your post was one that I referenced quite a bit when doing my research.
I love this amp.
Clay
PostPosted: Wed Mar 23, 2011 12:33 pm
Beautiful build, great pictures - really helpful - and I especially appreciate the fact that you have revealed your method of adhesion! It's either a thing so obvious that only a fool such as I needs to ask, or it's a well-kept trade secret!
