I'm happy to share that after many hours, I completed my Triwatt build on Wednesday! Considering my limited knowledge of electronics fundamentals and the fact that it's only my third amp build (the other most complicated being a 5e3), it feels like a huge accomplishment--especially because it fired up after testing/measurements with no real problems and runs very quietly! There's only
one strange issue that I wonder if anyone here has any thoughts about: the treble control does something weird in the final 1/12 or so of its travel (between ~5 o'clock and dimed). Up to this point, it performs as expected, but once it crosses this point there's a slight audible (through the speaker) pop, and the sound stays bright, but gets suddenly sort of choked or pinched sounding (though still bright). Seems strange, and I have no idea what kind of issue would cause this to only occur at the upper extreme of the knob's travel. I could live with it, but I'm OCD enough to want to chase down a cause.
In general, I'm really thankful to everyone who responded to my questions here and for all of the build topics on this forum that posted extremely helpful gut shots, particularly
matt_garman's,
Riise's, and
Gertjan's. Seeing all of the super neat wiring was really impressive, and though I'm not really capable of getting it that clean, it certainly upped my attention to detail and end results.
A few general notes from my build experience that may impact others:
-Not enough keps nuts came to accommodate the terminal strips that attach to the bottom of bolts shared with tube sockets; a hardware store trip fixed this for me! I also received 2 more terminal strips than I needed. Hmm...
-Where did everybody else get enough red wire? I didn't end up having enough to hit all of the connections labeled red. I was a bit confused about the manual's up-front instruction about which type of wire to use for which type of connection, and I ultimately figured it wasn't going to be a huge deal, so I used leftover red from the braided heater wire for a handful of connections.
-The input jack situation, 16 ohm hookup, and a couple other linked ground connections are a little confusingly depicted on the layout; it was helpful to see others' solutions for these.
-Why are there 2 red test points for bias?
-I broke the bias selector switch on installation--clip off the vertical locator tab on the washer it includes and make sure to use it! Otherwise if you over-tighten it'll break apart. I bought a 5-pack of replacements and one overheated when soldering connections, so I'd caution to be careful with this part in general (in addition to using as much insulation on unused lugs and wiring as possible per the forum post that discusses switch arcing).
-My kit was missing the 470Ω resistor so I temporarily replaced with a metal film 1/4 watt I had lying around. Maybe this has something to do with my Treble knob issue? Doesn't really look too related in the circuit though.
The amp sounds great with my (W)eber FC12, but I have a host of other options I'm looking forward to trying and reporting on in the appropriate topic. Once I install the replacement resistor, I'll take more comprehensive internal shots. For now I'll leave you with a shot of the righteous cab that Stephen made for me (sitting on a very expensive stand...matching white 2x12 speaker cab to come!) and a quick-and-dirty internal shot.
