It is currently Sat Jun 06, 2026 12:04 pm
 Post subject: Tramp Stack Build
PostPosted: Mon Aug 17, 2020 4:31 pm
I started this build a year ago and finally finished with the cabs last weekend. I'm a wood noob, but it came out better than I expected and so here is my show and tell. :thumbsup:
The sides and back are all pine. The fronts are 3/4 inch Russian Birch because that is what they had in smaller sized sheets.
The finish is oil based "golden oak" to make it look older. First it was a sealer, then stain, then 4 coats of supergloss oil varnish. The gloss was sanded and I was going to put on 4 more coats, but It looked like it fit in this state so I left it.
I can also run the lower box solo on the side with the head on top for a clean looking mini tower.
The head is 16 X 9 high and 8 deep. It's tall for el84s and 6L6.
Top box is 14 X 20 X 9.5 deep with a new 10 inch Celestion Alnico Gold 40 watt. 16 ohm
Lower box is 16 X 20 X 9.5 with a Celestion Greenback 25 watt that has seen a few years of use already. 16 ohm.
The sound is great. I've got about 10 hours on it and the Gold is breaking in nice. The balance is good with a little more from the Gold which might all be top end and mellow a bit with age. The best part is the bass. It sounds really connected and not like some strange thing lurking under the sound. Maybe this is the pine or maybe I just lucky on dimensions and the back hole. Volume level is about the same as it was with a single v-type speaker that it was running, it feels louder because the range is wider. The two speakers are very happy together and the react different during soft dynamics and tails. It's a joy to play.
There's one visual problem with the piping along the top edge of the top box being a bit pushed in. I'm going to take the front off and clean that up.
The Tramp is an awesome amp and I'm super happy with this experience and Trinity Amps.
https://i.imgur.com/iQQ2lO0.jpg
https://i.imgur.com/Z3lgq9O.jpg
https://i.imgur.com/yg2mfOz.jpg
Bonus image. Don't let the strat fool you!
https://i.imgur.com/WsB442K.jpg
 Post subject: Re: Tramp Stack Build
PostPosted: Tue Aug 25, 2020 9:20 am
Eh, why are you calling yourself a wood noob? That looks like quite a good job to me, and you've turned a great amp into an unique and great amp!
PostPosted: Wed Aug 26, 2020 3:54 am
Thanks Flanker, but I am a wood noob! It makes me want to build another, but first I want to play this one for a year or two.
Here's a song I made to see how it sounds http://machinesfromfaraway.com/files/bo ... 0goat2.mp3.
The amp has a 6L6 in for this. There's 4 guitar tracks all recorded through both speakers. Sometimes mixed together and sometimes panned. The 10 inch had a 906 on it and the 12 inch had a sm57. The guitar is a 2019 gibson SG '61 stopbar. There's some boost on the leads and some mrx verb on guitars. The speakers are about 10 hours broken in. I didn't spend much time. I wrote the song and recorded it in a couple hours. I just wanted to hear how it sounds. Nice and retro!
