It is currently Wed Apr 08, 2026 3:18 am
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Fri Nov 25, 2011 12:14 pm
yeah they're dual ganged.. so I need to move the jumper wire and resistor to the top row with the rest of the connections?
and yeah.. they're about twice as thick
PostPosted: Fri Nov 25, 2011 12:34 pm
made the changes... treble, master volume and VRM all seem to work. The volume and bass push pull are still not working.
PostPosted: Fri Nov 25, 2011 12:36 pm
you made those changes to BOTH of those dual ganged pots right?
PostPosted: Fri Nov 25, 2011 12:40 pm
I didn't have to make any on the bass. Also,when fat mode is engaged the sound gets louder.
PostPosted: Fri Nov 25, 2011 12:51 pm
Only using one of the gangs on the Bass pot and have the wire from the treble pot lug1 to bass pot lug 3?
PostPosted: Fri Nov 25, 2011 12:59 pm
Yes
PostPosted: Fri Nov 25, 2011 1:23 pm
On the switch associated with the volume pot. the short purple jumper should go to the center lug of the switch. is there a short to the outer lug on the switch?
PostPosted: Fri Nov 25, 2011 1:29 pm
so the jumper should go to lug 2? I have it on 1. I'll make the changes.
PostPosted: Fri Nov 25, 2011 1:36 pm
wait!!! It's ok on the pot end.. but it looks like there might be a short between 2 lugs on the SWITCH!!!
PostPosted: Fri Nov 25, 2011 1:41 pm
ok, i didn't make the changes cause I reread what you said... so which lugs on the switch should i be checking?
PostPosted: Fri Nov 25, 2011 1:46 pm
look to where the short purple wire attaches to the SWITCH. It should go to the center of the 3 lugs. It looks like there might be a short from there to the adjacent lug on the switch ( the one with the 220K resistor)
PostPosted: Fri Nov 25, 2011 1:55 pm
nope, no short.
PostPosted: Fri Nov 25, 2011 2:08 pm
So the volume (gain) control has absolutely no effect?
PostPosted: Fri Nov 25, 2011 2:12 pm
correct
PostPosted: Fri Nov 25, 2011 2:16 pm
when you migrated all the wires to one gang you included the center conductor of the shielded wire?
PostPosted: Fri Nov 25, 2011 2:19 pm
yes. all of the connections are on the correct lugs on the top gang.
PostPosted: Fri Nov 25, 2011 2:22 pm
Can you check with an ohmmeter that Lug 1 of the volume pot is grounded!? It does so via the input jack which itself has a ground connection at the lug bolted to the chassis.
PostPosted: Fri Nov 25, 2011 2:27 pm
pardon my noob-ness... but how do I go about doing that?
PostPosted: Fri Nov 25, 2011 2:35 pm
Turn off the amp. Set you meter to the ohms scale. If you short the leads together you should get Zero ohms or at least very low ohms ( 1 or 2?). Now put one lead on lug 1 of the volume pot and the other to any spot on the chassis. You should see the same "near zero" reading. If so you can do the same from lug2. Then as you rotate the pot the readings should go from near zero up to several hundred of kilohms.
PostPosted: Fri Nov 25, 2011 4:31 pm
both readings were what they should be.
