It is currently Thu Apr 16, 2026 5:29 pm
 Post subject: zener
PostPosted: Fri Mar 04, 2011 11:50 am
zener. Hard to tell negative end.??does it go between mosfet resisters? Hard to see in pic's.
 Post subject: Re: zener
PostPosted: Fri Mar 04, 2011 4:53 pm
Check the layout. There is a band at the cathode of the zener, it points 'towards' the MOSFET.
PostPosted: Fri Mar 04, 2011 5:18 pm
Or to explain a little further, the cathode (stripe end) is the one shown on the schematic as a crooked bar. HTH
PostPosted: Fri Mar 04, 2011 5:35 pm
..which would be this...
PostPosted: Sat Mar 05, 2011 3:51 pm
Thanks guys,hearings gone from the marshalls,eyesight by age.And that drummer,never could modulate it down. Just making sure everything is correct. I have done old (1940,1960 bogen)mod to guitar,never a board,all terminal... The build is going well,and I will turn these virginia guys onto this.
 Post subject: Re: zener doubt
PostPosted: Thu Apr 14, 2011 12:24 am
Glad I found this thread.
That diode is so small, I had trouble figuring which way it goes.
My multimeter gave me part of the answer, but I'm reassured to read here confirmation that I had installed it the right way.
