 Post subject: zener in VVR
PostPosted: Tue Feb 11, 2014 7:44 pm
What wattage is the zener in the VVR circuit?
Randy Magee
 Post subject: Re: zener in VVR
PostPosted: Thu Feb 20, 2014 4:35 pm
No one?
Randy Magee
PostPosted: Thu Feb 20, 2014 6:00 pm
1W if I remember correctly but it might be 1/2W. Email Trinity and us to be sure though.
As a side note it never hurts to have a part over speced but not the other way.
i.e. if a design calls for 1W you can easily use a 2W part but can't use a 1/2W part.
PostPosted: Mon Feb 24, 2014 10:46 pm
6V 1W ZENER DIODE
PostPosted: Fri Mar 07, 2014 12:22 am
I am using a 1/2 watt 6V zener with no issues yet.In my VRM but I do have the HT fused.
But you can use 2 x 3V 1/2 watt zeners to make a 6V 1 watt if you have them on hand.
But unlike resistors you can't parallel two zeners to double the power handling.
You have to run them in series to add up the voltage and wattage ratings.
I hope that helps
PostPosted: Mon Mar 10, 2014 5:35 pm
Good tip on the Zener.
