 Post subject: Effects loop?
PostPosted: Thu May 08, 2014 11:40 pm
Hi guys, just finished my Tramp (first build ever, yay!) and having a great time with it. I'm wondering though, is it possible to add a passive effects loop? I've never been a fan of reverb and delay up front.
~fredster
 Post subject: Re: Effects loop?
PostPosted: Wed May 14, 2014 11:01 pm
Anyone? Maybe a more specific question. I took a look at Mojotone's loop, but even though I have the head version of the Tramp, I don't think I could get it to fit. I'd like to use rack effects, not pedals so I think a simple insertion point might all I need. I am pretty new at this, so does anyone know if this is technically possible in a Tramp?
~fredster
PostPosted: Thu May 15, 2014 7:20 am
Yes it's possible. You can try inserting a loop jack just just before the master volume. If that overloads or drive the effect too much, try just after C2. Passive loop might work OK within limits.
PostPosted: Thu May 15, 2014 8:05 pm
Thanks, I'll give it a shot!
~fredster
PostPosted: Thu May 15, 2014 11:14 pm
Just to follow up -
Got some jacks wired in between the treble and master volume (signal to tips, sleeves to ground). It kinda worked, the effects unit I have is designed for unity gain, but the signal seemed pretty hot going in and I lost some volume going out. I wasn't able to really balance out the levels. Which is probably what I should have expected based on what I've been reading. Then I tried in between C2 and Volume/Gain. The levels evened out a bit but I didn't like having the effects before the tone stack. It sounded similar to just running them up front. I may revisit this after I learn a bit more about how this all works. Thanks for the advice Stephen, at least I learned something!
~fredster
PostPosted: Thu May 15, 2014 11:30 pm
Thanks for the follow-up. Good to know. It might work with other effects tho,
PostPosted: Fri May 16, 2014 9:58 am
fredster wrote:
Just to follow up -
Those are the only two places you can really put it unfortunately.
As noted right after the first triode isn't that different from "out front" because well the only thing between that spot and the input is a couple components and half a tube.
You could try a buffering and scaling/mixing circuit for better results. That's adding a lot of complexity to such a simple design though.
PostPosted: Fri May 16, 2014 10:14 am
I agree, it's probably not worth it in this amp. A great learning experience though, to be used on a future 18w build :)
~fredster
PostPosted: Fri May 16, 2014 10:48 am
For sure :thumbsup:
