 Post subject: 6L6/6V6 switch question
PostPosted: Thu Apr 19, 2018 10:49 am
Just about to finish up my tramp build, and have a question about this switch for my own curiosity.
When ohming out the switch, the middle lugs, or lugs #2 in my pic are basically always on. So when the switch is in the up position, it is running lugs 2 and 3, which is only the 6V6 resistor (750r) , and when the switch is down it is running lugs 1 and 2, which will be running BOTH the 6v6 and 6l6 (750r and 560r) resistors
Am I understanding this correctly?
Thanks guys!!
Dan
PostPosted: Sat Apr 21, 2018 3:12 am
That's right. In the 6V6 position only the 750 ohm resistor is connected to the output tube's cathode.
In the 6L6 position, both the 750 ohm and the 560-ohm resistor are connected to the cathode. They are connected in parallel which results in about 320 ohms. This provides the additional bias the 6L6 needs.
PostPosted: Sat Apr 21, 2018 11:22 am
Thanks for your response! The build has been going great. I have a 10 month old daughter so I've only been working on it 20 minutes here, 45 there, but its coming along and I just need to attach the leads to the board and fire her up.
It's been a great learning experience seeing all the stuff I've read about as something tangible.
I should probably wait to see if I did this one right but I'm already planning my next build haha
