It is currently Sat Apr 18, 2026 12:11 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 22, 2007 11:15 pm
http://www.aikenamps.com/SafetyTips.html
PostPosted: Tue May 22, 2007 11:18 pm
+1 for Leemo and jcny
PostPosted: Sat May 26, 2007 9:13 am
I contacted the Tubestore I spoke to Jon (excellent service). He suggested that I lightly tap all of the pre-amp tubes with the amp on to locate the microphonic pre-amp tube. I did this and found no difference but I noticed that one of my power tubes (stock Fender installed stuff) was not glowing. Jon mentioned that I should re-seat the offending tube and see if that could correct itself and he said that also might be the problem of the strange noises. I re-seated the tube this did not correct the problem so I switched the tubes around and the power tube when on but flickered off. Jon said that the tube is probably shorting out internally and I should replace at lease two tubes. I ordered a whole new set power and pre-amp tubes just in case... The Tubestore gives excellent service-they were very patient with me.
If you hear that the power grid goes down in Quebec you know the Bubbleboy has popped while changing his tubes.
Bubbleboy
PostPosted: Sat May 26, 2007 12:52 pm
I'm going to suggest this, but I know you don't have this. Someone else might to want to chime in.
I clean ALL my tube sockets prior to putting tubes in them. :D
I use "Techspray" Kleen-it Cleaner/lubricant. Works wonderful :D :D. Most people don't have this.
Coco is there another way. I'm so use to doing this I've never investigated another way :? Leemo, what do you use.
I think this might solve issues with his amp.
Later,
Jac
(edit)
+1 for the Tubestore
PostPosted: Sat May 26, 2007 1:46 pm
Thanks for the tip... I'll go and get some right away.
bubbleboy
PostPosted: Sun May 27, 2007 8:20 am
I use basic contact cleaner and gently 'roll' the tube around with the pins in the socket.
Yes, The Tube Store is great.
http://store.yahoo.com/cgi-bin/clink?thetubestore+rxJgZB+index.html+
PostPosted: Mon May 28, 2007 5:45 pm
jac,
Sorry that I didn't answer right away. I've used Rat Shack cleaner and Blue Shower. Moreso on pots that sockets. I usually just rotate the tube as I pull it out and then back in. It seems to work so far. I'm probably just loosening the clips :oops: but it plays well with my lazy lifestyle. 8)
LeeMo
PostPosted: Mon May 28, 2007 5:51 pm
No problem take your time. Appreciate the response.
I'm finishing the wiring. Taking a break right now. The power up on the sIII will take place today. The wiring hurts my eye's. The combo so tight. :shock: So I have to keep taking breaks. Have to keep putting in my tear drops in every time I break. (Don't ask)
