It is currently Fri Apr 17, 2026 8:44 pm
 Post subject: ABY switching
PostPosted: Sat Nov 29, 2008 2:42 pm
It occurs to me, tooling around with two amps (Trinity Deluxe and Trinity TC-15, of course!) running at the same time, or sequentially, that some others may have good advice for me and others on the forum as to what you've found to work well.
I've used a couple of different ABY stomps, and like my Startouch for quality build, low noise, and fair price. But without transformer isolating circuitry, there is some signal loss in the Y (both amps engaged) mode.
So, what do you use that you like for this application?
PostPosted: Sun Nov 30, 2008 4:38 pm
I havent tried any but I see the Morley ABY Channel Switcher out there. I have a friend who says he can build me a better one with no switching noise. I'll ask him about the gain factor as well in Y mode.
PostPosted: Sun Nov 30, 2008 6:09 pm
Thanks, Stephen. Lehle has a transformer-isolated switcher that has gotten very good reviews, but it is pricey. As in $230 for their simplest ABY control.
PostPosted: Sun Nov 30, 2008 7:27 pm
I know that Keeley makes one for Peter Frampton that gets very high marks. The Radial Tonebone switcher is supposed to be very good as well. Of course they're not giving either one of these puppies away :roll:
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Sun Nov 30, 2008 8:44 pm
I have a Radial Bass Tonebone, and it's excellent.
PostPosted: Sun Nov 30, 2008 9:04 pm
Radial Tonebone for $259.99 - ouch!
PostPosted: Mon Dec 01, 2008 9:11 am
I mostly use the Tonebone for running two basses into one amp. Being able to do a little bit of level-matching and EQ between instruments makes it a very valuable tool. It's much more than a passive switcher.
PostPosted: Mon Dec 01, 2008 11:19 am
Once you add transformers into the mix you can pretty much plan on paying some serious additional coin. I have seen some schematics for home brew switchers/combiners that may save a bit.
I've noticed a few pedal boards with built in switching/looping functions (Furman or SKB maybe?) Has anyone tried these?
Joe G
 Post subject: Another option....
PostPosted: Tue Feb 10, 2009 8:04 pm
Another option....
I asked Greg of Solid Gold FX in Canada to make me a custom ABY/Boost pedal.
It's a normal ABY pedal with stereo and mono output jacks and it also has an isolated input and switch to activate my plexi's clean boost. It works very well and its compact size makes it handy to throw in my gig bag.
Cheers,
Brian
Sorry for the shameless plug :-)
picture =>
http://s437.photobucket.com/albums/qq93 ... _pedal.jpg
Greg's info:
Solid Gold SoundLabs - Custom Guitar Effects & Mods
Web: SolidGoldFX.com
Email: info@solidgoldfx.com
Montreal, Canada
PostPosted: Wed Apr 29, 2009 4:15 pm
I can't believe how much these things cost... I just want to run stereo amps haha.
PostPosted: Wed Apr 29, 2009 5:33 pm
here is one http://www.geofex.com/FX_images/humfree2.gif
http://www.burningheart.com/_lib/util/s ... =2517&s=hi
