PostPosted: Thu Feb 04, 2010 1:11 am
I have an amp that I am working on (based on the 5F6A) which has a rectifier tube. I am looking to do away with it for size/simplicity reasons. Trying to work in another few things into the chassis and the tube rectifier holds some valuable real-estate (small chassis but amazingly quiet).
My question is... with a pair of 6L6s and a PT that's 650VCT- would it be too much to just bypass the rectifier tube and simply replace it with some diodes? Do I need an additional voltage drop now that the RT is gone? I have done a few SS rectifier designs in the past- but I am just not sure what the 6L6s can handle.
I'm sure a similar situation has been encountered in the past... if someone has got a link- just point me there and I'll be on my way.
Also Coco- the Tramp sounds like it's going to be killer.
PostPosted: Thu Feb 04, 2010 4:16 pm
Also... anyone have any comments on cathode bias? I am thinking about changing that to get a little more sing out of it.
Basically the amp is a fattened up version of the Bassman 5F6A "bright" channel, and the normal channel has been replaced with a Voxy/TC-15 Ef86 channel. Sounds pretty cool, but because of the fact that there is less grit coming through the power tubes (when compared to an EL84 amp)- I'd like to either add a boost or even an additional switchable gain stage to the EF86 channel... unless the cathode biased version on the poweramp gives a little more breakup (and a little drop in voltage). Good/bad idea?
As of now I have changed out the rectifier tube/socket for 4 1N5399 rectifier diodes, tying off the 5V taps. Haven't tested it yet.
PostPosted: Thu Feb 04, 2010 5:28 pm
Tested at 505V on the B+ w/out tubes. So... 360V-ish right? I'm thinking it should be fine.
But I am still curious about opinions on the cathode biased Bassman.
PostPosted: Thu Feb 04, 2010 6:03 pm
I feel like I am talking to myself... and I take pity on those who are reading this. But any help is much appreciated!
I took some measurements with and w/out tubes. But I have a problem. The plates on the 6L6s start to glow as they're hit with the B+. What could be the cause of this? I have only powered on for short periods of time as to not damage the tubes.
Measurements:
B+: 391V
OT Primary: 373V
Fliter Caps W/tubes
#1/#2 (parallel): 389V
#3: 379V
#4: 343V
Filter Caps W/out Tubes
#1/#2 (parallel): 505V
#3: 502V
#4: 498V
PostPosted: Sat Feb 06, 2010 1:24 am
Problem= crappy soldering job in the bias circuit.
Solution= start doing a better job soldering!
But it's all good now.
