It is currently Fri Apr 17, 2026 10:29 pm
 Post subject: Tolex adhesive
PostPosted: Thu Mar 25, 2010 11:30 am
How long do you guys leave contact adhesive to dry before you put them together? Do you time it so you have a few moments to pull it into place if need be?
PostPosted: Thu Mar 25, 2010 12:53 pm
Depends on the type. Solvent based Gen Purpose you have some time if you don't press too hard. Solvent based Heavy duty is less forgiving.
I don't use water base because it takes too long to dry.
Contact cement is pretty well instant contact adhesion.
PostPosted: Thu Mar 25, 2010 1:33 pm
The stuff i have made by Bostik, it's solvent based, quite a runny thin solution in a can. I just experimented with it by making some piping and it bonded after about 4 minutes.
I'll need to be confident to use it for a full amp covering.
