PostPosted: Fri Jul 22, 2005 10:53 am
Steven,
I am in the same boat. I have been thinking about a Metroamps Superbass. I am afraid that the Bassman might be underpowered? I wonder what ever happened with bnwitt's Marshall Major project?
Broz
PostPosted: Fri Jul 22, 2005 12:24 pm
Marshall Major? Holy cow!!
Man, knowing what I know now...I dont think I'd own or build a tube amp bigger than 30-40 watts. I can't imagine having a 200 watter lying around....
PostPosted: Fri Jul 22, 2005 3:03 pm
was thinking something a little more uncomon, might do a trainwreck, always could do a 59 super lead so i could be jimi of maybe not jimi but have a lot of volume any way, what about an ef86 front end with a super lead 4 el34 power section, thay would be uncomon.
just tring to brain storm any thoughts. ?
PostPosted: Fri Jul 22, 2005 4:33 pm
Frank,
I agree for guitar, but pushing air for bass is a little different.
Broz
PostPosted: Fri Jul 22, 2005 4:48 pm
Oh, this is for bass? Ahh..sorry! :)
Bass, a bare minimum wattage is 100 watts.....if not more...
PostPosted: Sat Jul 23, 2005 12:34 pm
What sorta bass sound in what sort of setting? There's all sorts of answers, only some of which are good in certain instances. (A good 50-60 watts can sometimes be just fine for bass, like old Ampeg flip tops.)
Bear
PostPosted: Sat Jul 23, 2005 12:41 pm
Well, let's start with a low powered version. The Bassman was not 300W.
Basic amp, minimal frills, for a non-professional player.
PostPosted: Sat Jul 23, 2005 6:27 pm
Well, the Tweed Bassman was a 50 Watt Bass amp before it was hijacked by the blues and rock players. With ten years or so trying things I think Fender got it right in the 59 model then everyone got sold the high power is best theme from the manufacturers. I have used the 59 with a bass and I think it sounds great, I was thinking of putting together another bass amp prior to building the 5F6A but I won't bother now. If they don't like it it's an easy sell at the end.
Nigel
PostPosted: Sat Jul 23, 2005 7:22 pm
So, the circuit you recommend for a Bassman build is the 5F6A then?
PostPosted: Sat Jul 23, 2005 10:03 pm
The blackface Bassman heads can actually be pretty good for bass. what's good about them is there's less preamp gain and more voltage swing on the power stage, with sag-free solid state rectification and some hefty output iron. Kind of goes the same for Showman heads, too.
I think the irony has been pointed out that the 59 Bassman reissue is electronically a better bass amp than the original do to higher plate voltages and the solid state rectifier. If you need to do tube rectification on a new build for bass, use two as was original equipment - much less sag.
Bear
PostPosted: Sat Jul 23, 2005 10:08 pm
Yeah, I was pleased with the 5F6A build but remember I built it as a guitar amp not for bass. Not being a bass player and only using it on lowish volumes works OK but I have not cranked it with the bass so can't comment on the rectifier sag, however it wouldn't be too difficult to replace the tube rectifier or maybe even use a copper cap?
Nigel
PostPosted: Sun Jul 24, 2005 9:44 am
I would love to make a mid 70's SVT. I had the pleasure of using one for a few years in the late 80's and really don't think there's an amp out there that sounds as good with my Jazz Bass. Sonic nirvana... Perhaps a Portaflex B15 comes closer then most.
"See, in my line of work you got to keep repeating things over and over and over again for the truth to sink in, to kind of catapult the propaganda." —George W. Bush, Greece, N.Y., May 24, 2005
PostPosted: Sun Jul 24, 2005 9:57 am
I guess google is really that good.
http://www.drtube.com/guitamp.htm
