It is currently Tue Mar 03, 2026 2:42 pm
 Post subject: 63/37 solder
PostPosted: Tue Feb 01, 2011 3:30 pm
I was reading on the Webber site that Ted preferred to use 63/37 solder as it apparently sets more quickly than 60/40 solder. Does anyone have experience with this ?
 Post subject: Re: 63/37 solder
PostPosted: Tue Feb 01, 2011 5:23 pm
I've been lurking and wondering if anyone is using silver solder...
PostPosted: Tue Feb 01, 2011 7:13 pm
don't know about the 63/37 but as far as silver solder is concerned...I beleive it's melting point to quite a bit higher than tin/lead solder. Don't know if a little 40watt bench soldering pencil would do the trick.
PostPosted: Tue Feb 01, 2011 7:22 pm
It has a lower melting point, therefore will set up quicker. It was used in solder bath for wave soldering PCBs, don't know if thats still the case.
Silver solder has its place and this isn't it.
Tele's make the best noise
PostPosted: Tue Feb 01, 2011 10:26 pm
Just bought some 63/37; besides being smaller in diameter I can't tell the difference. Also bought a spool of silver and I'll tell you that stuff is very hard to work with. Completely gumed up a pedal I was working on. Can't recommend Silver solder.
PostPosted: Wed Feb 02, 2011 2:45 pm
There is some discussion on this in the Resource section.
I build for Uncle Sam and we're now using Kester 245 or 285 solder, type depending on if we need a "no-clean" flux or not. Lead-free is not allowed because of the "whiskers" (and it sucks!), silver solder has a melting point that is too high for some heat sensitive components.
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Sat Mar 12, 2011 1:53 am
I use 62/36/2 silver solder .022 dia. It sets quick and melts quick and makes clean joints. I also use the 63/37 on some things in .030 dia. clear resin.
PostPosted: Sat Mar 12, 2011 8:31 am
Well I ended up getting the 63/37 for the Amp Camp, and it worked fine. I have no experience to compare it to anything else.
