It is currently Sun Sep 06, 2026 7:10 pm
 Post subject: Amp Chassis Building
PostPosted: Wed Nov 27, 2013 5:47 pm
Hi, I need some advice on how to drill holes for tube sockets in an aluminum chassis. The holes need to be 1 3/16" and I don't have a step drill that big. Would a holesaw be the best tool?
Thanks, Dave.
 Post subject: Re: Amp Chassis Building
PostPosted: Thu Nov 28, 2013 12:32 am
goindeaf, ME TOO, :rol
Hole saw would be okay, best if in a drill press at proper speed.
HTH,
Gene
PostPosted: Thu Nov 28, 2013 12:10 pm
Go easy on the hole saw & it should work. If you can, use some cutting oil or lubricant to help. A punch that size can run around $50, but you could get one from Home Depot or similar place.
PostPosted: Thu Nov 28, 2013 12:43 pm
Thanks guys, I'll give the holesaw a try.
Dave.
PostPosted: Fri Dec 02, 2022 10:32 am
goindeaf wrote:
Thanks guys, I'll give the holesaw a try. foodle
Dave.
I use cutting oil to help with my sawing problem very well. Have you tried yet?
PostPosted: Thu Nov 02, 2023 7:21 am
If you're careful with the hole saw, you should be fine. Use a lubricant or cutting oil to make things easier. You may find a suitable punch for the job for roughly $50 at Home Depot or a similar store. wordle today
PostPosted: Tue Mar 18, 2025 11:27 am
A hole saw is a good option for drilling 1 3/16" holes in an aluminum chassis if you don’t have a step drill. Make sure to choose a hole saw designed for metal, as it will provide cleaner cuts. Using a pilot bit helps keep the avatar world hole centered. After cutting, you can file or deburr the edges to achieve the exact size.
PostPosted: Mon Aug 11, 2025 2:59 am
Hey Dave, I've tackled this before! A holesaw can work, but go super slow and use cutting oil to avoid grabbing and making a mess of the aluminum. Ideally, a chassis punch is the cleanest way, but they can be pricey if you're only doing a few holes. Speaking of specialized tools, this whole process reminds me of those tiny little cars they had on that old show… the Eggy Car comes to mind! Good luck with your project – patience is key!
