PostPosted: Mon May 21, 2007 9:25 am
I'm building a Tiny Terror clone using a layout i've drawn up from a schematic i got from 18watt.com/Ampage. I was planning on using IN1007 rectifer diodes for the clone. Would a standard 4 diode bridge be possible with them? Also, the schematic calls for a 10nF cap across the bridge. What would the purpose of this cap be and what kind of rating is needed? I figured 1KV just to be safe but would i get away with 630V? Its a 15 watt amp with the HT windings producing up to 290V.
Simon
PostPosted: Mon May 21, 2007 2:33 pm
1N4007s will work just fine. And yes, you can build a bridge with them. The 10nfs are added to lower switching noise pollution. You don't have to add them. If you use the Ultra FRED style diodes (like UF1N4007), then you don't really need the caps either.
Richard Johnson
PostPosted: Mon May 21, 2007 5:19 pm
Cheers!
Simon
PostPosted: Mon May 21, 2007 7:21 pm
Wicksy,
Since you started this thread, how about posting that layout here, That would be great for everyone... and me :lol:
I'm very curious about th design.
Thanks, Jac
PostPosted: Tue May 22, 2007 5:34 am
People in the UK can buy fast recovery rectifiers from Maplin which work like FREDs. I recommend using them for reducing power supply buzz.
PostPosted: Tue May 22, 2007 4:32 pm
jac wrote:
Wicksy,
Thanks, Jac
Will do! :wink:
Simon
PostPosted: Tue May 22, 2007 10:36 pm
Thanks Wicksy,
I'll have to try the Fred's, Zaphod
Jac
