It is currently Sun Jan 25, 2026 5:44 am
 Post subject: Jumper wire????
PostPosted: Tue Aug 30, 2011 8:15 pm
connect a shorting jumper between the plate of a preamp tube and chassis ground. This jumper will drain any high voltage to ground through the 50k to 100K 2W plate resistor on the tube. To do this successfully, you will need to know which pins are the plate pins.
I know what the chassis ground is but what is the plate between the preamplifier tube mean? I don't know what the plate pins are. 18watt Plexi.
Rich
 Post subject: Re: Jumper wire????
PostPosted: Tue Aug 30, 2011 8:31 pm
Rich,
Do you have our kit Builders Guide? There is an entire section devoted to this. I suggest you take a look at it and get familiar with the terms. Let me know if you would like that reprint section.
PostPosted: Tue Aug 30, 2011 10:12 pm
Yes I have the builders guide. I have read it but it is all Greek to me. I just need to see a picture of the jumper wire then I can move forward to my next newbie question.
Rich
PostPosted: Wed Aug 31, 2011 9:31 am
Pin 1 or 6 on V1.
Or to always have them drain automatically attach a 220K 2W resistor from the first terminal on the cap can to ground.
PostPosted: Wed Aug 31, 2011 11:52 am
Thank you.
Rich
