It is currently Thu Jan 22, 2026 6:47 pm
PostPosted: Fri May 03, 2019 4:40 pm
I have a trinity Slll that I built a while ago. It has a celestion G12H Herritage 55hz 16 ohm 30 watt in a 1x12 closed back cabinet. It sounds pretty bassy, unfortunately I can't keep the amp cranked up where the tone is ok. The amp is used at home so I need to keep the amp at somewhat lower levels. I ordered the VRM module today. I'm thinking of replacing the G12H with the celestion g12m herritage which is 96db but only 20 watts. I not sure if this would be a problem or not because of the speakers low wattage ? Or maybe the celestion G12m greenback 25 watt speaker. I play mostly classic rock & blues from around the mid 60's to early 70's (Bluesbreakers, Jeff Beck, Hendrix, Led Zeppelin). And the speaker has to go in a 1x12 cabinet
because of space. Any help would be appreciated.
PostPosted: Fri May 03, 2019 9:55 pm
I have a G12M 25 watt paired with my 18 watt Plexi. I use it both open and closed back and really like the tone. It’s suffered no ill effects from the amp cranked. I play the same type of music as you. And these speakers have been made in the UK since April 2018.
PostPosted: Sat May 04, 2019 8:27 am
Yea, I was leaning toward getting the gm12 25 watt speaker. Although a friend of mine has a marshall 1974x and I do like the gm12 herritage 20 watt tone. I read a few threads about scummback speakers being close to the old greenback tone. Do you know anything about those speakers.
PostPosted: Sat May 04, 2019 8:32 am
I’ve heard good things about Scumbacks. No experience with them myself. WGS has the Green Beret that gets good reviews. I’m very pleased with my Celestion and the price was reasonable for a UK made speaker I felt.
PostPosted: Sat May 04, 2019 9:24 am
I have the wgs green beret in a 1 watt gilmore jr. that I built a number of years ago. It does have that 60's blues/rock tone.
For the sIII think I want to stay with the celestion speakers, do like their quality and tone. I'm going to order the celestion G12m 25 watt greenback today. Since I can't fully crank the amp up because of home use and I'll be installing the VRM mod 25 watts for the speaker should be OK. Thanks for the suggestion and help.
PostPosted: Sat May 04, 2019 9:48 am
I bought this one in January.
PostPosted: Sat May 04, 2019 9:59 am
I just sent an email to zzounds asking if their current stock for the celestion g12m 25 watt is the Made in China or the Made in UK/England speaker. Waiting to hear back from them before I purchase. Thanks for the pictures.
PostPosted: Sat May 04, 2019 11:16 am
Where did you purchase the g12m 25 watt celestion, I would like to get the UK made speaker ?
I just heard back from zzounds there reply was:
Hello,
Thank you for your email.
​Celestion Greenbacks will be exclusively made in China currently.
PostPosted: Sat May 04, 2019 4:44 pm
I’m in Canada. I bought it from https://qcomponents.ca/12-guitar-speakers.html
JD28 equals September 28, 2018.
https://celestion.com/speakerworld/guit ... _speaker?/
PostPosted: Thu Aug 08, 2019 8:45 pm
Late to the party, but I'm using a lightweight semi open 1x12 cab with a Scumback M 75 PVC with my 18 TMB. It's a classic sound for sure, love it! I have a second identical cab with a Scumback J 75, which isn't all that far from the speaker mentioned above. I also use either one of these cabs as an extension with a upgunned 5F2 Princeton 1x12 combo clone, and it's great with that also.
Their deal is recreating some of the cool Celestions from through the years, and while I don't have the experience with old Celestions to say if they're hitting it, I can say they recreate the sound of the 60s and 70s when it comes to rock.
PostPosted: Sat Aug 17, 2019 3:33 pm
Try an open back cab (take the back off for now and listen to it)
PostPosted: Sat Jun 27, 2020 10:18 am
Case24 wrote:
I have a G12M 25 watt paired with my 18 watt Plexi. I use it both open and closed back and really like the tone. It’s suffered no ill effects from the amp cranked. I play the rachat crédit consommation same type of music as you. And these speakers have been made in the UK since April 2018.
I’ve thought about increasing the cathode resistors on V1a and v1b to 1.5K each from the current 820 ohm each to reduce some gain.
Users browsing this forum: No registered users and 44 guests
