It is currently Wed Dec 03, 2025 11:59 pm
 Post subject: HELP!!!!
PostPosted: Thu Oct 09, 2008 11:56 am
I just finished my 5e3 and my voltage readings are really high.
12ay7:
Pin 1 : 314 (need 120)
Pin 3 : 4 (need 1.1)
Pin 6 : 310 (need 123)
Pin 8 : 4 (need 2)
12ax7:
Pin 1 : 385 (need 167)
Pin 3 : 3 (need 1.1)
Pin 6 : 486 (need 175)
Pin 8 : 108 (need 70.5)
6v6:
Pin 3 : 851 (need 380)
Pin 4 : 797 (need 338)
Pin 8 : 53 (need 22)
6v6:
Pin 3 : 849 (need 382)
Pin 4 : 795 (need 339)
any ideas where i messed up?
:::::update i made a stupid mistake...meter was on ac instead of dc.
here are the new readings:
12ay7:
Pin 1 : 143 (need 120)
Pin 3 : 2 (need 1.1)
Pin 6 : 142 (need 123)
Pin 8 : 2 (need 2)
12ax7:
Pin 1 : 177 (need 167)
Pin 3 : 1.4 (need 1.1)
Pin 6 : 220 (need 175)
Pin 8 : 49 (need 70.5)
6v6:
Pin 3 : 384 (need 380)
Pin 4 : 361 (need 338)
Pin 8 : 24 (need 22)
6v6:
Pin 3 : 386 (need 382)
Pin 4 : 362 (need 339)
some of these seem off by a bit did I mess up?
PostPosted: Thu Oct 09, 2008 12:06 pm
PostPosted: Thu Oct 09, 2008 3:34 pm
12ay7:
Pin 8 : 2 (need 2)
12ax7:
6v6:
6v6:
PostPosted: Thu Oct 09, 2008 3:40 pm
Those voltages seem insane. I'm no expert but are you sure you're using the proper tools and measuring the voltages the right way?
PostPosted: Thu Oct 09, 2008 3:54 pm
Those voltages look good to me.
PostPosted: Thu Oct 09, 2008 4:05 pm
cool...also i notice as i mess with the volume knobs i get some squealing, is this normal?
PostPosted: Thu Oct 09, 2008 9:41 pm
Coco has some diagnostic help for squealing in his instructions.
PostPosted: Thu Oct 09, 2008 10:45 pm
Yes, if you are getting squealing, try reversing the OT leads to the output tubes. They are colour coded and should be fine if you followed the layout, but you never know.
PostPosted: Fri Oct 10, 2008 12:13 am
I checked my wiring with the diagram and it is exactly what it should be, but I'll try reversing it and let you know what happens
PostPosted: Fri Oct 10, 2008 10:18 am
found it...It wasn't the OT lead though....I had missed soldiering the middle lug ground connection on two of the the input jacks. she's all quite now...thanks for all the help...sound clips will follow..:-)
PostPosted: Fri Oct 10, 2008 10:36 am
The voltages will run on the high side with JJ (and perhaps some other) currently produced rectifier tubes. You might try a NOS in that position if you don't already have one installed. Then decide which sound you like best. NOS are pricey, but hey, money will soon be worth nothing anyway with the US stock market collapse. :? But your voltages shouldn't be a problem as is (as are?).
