It is currently Sat Dec 13, 2025 11:44 am
 Post subject: hisssssss
PostPosted: Wed Dec 10, 2008 9:49 am
I know that my wiring is far from perfect, but the hisss seems to be especially loud in my amp. I have isolated the hiss to the 'cut' control. When I turn the knob all the way up (furthest clockwise) there is almost zero noise, however with it turned all the way down, there is quite a bit of noise. So the questions is...
Is there any way to determine where to start looking for cold joints/bad grounds (i.e. preamp/poweramp) based on this information?
Any additional comments are welcome.
Thanks in advance :D
PostPosted: Wed Dec 10, 2008 2:30 pm
Carbon comp resistor amps have a definite hiss level. It's not a HI Fi amp!
Assuming it's not a tube, if you want to get rid of it, you'll need to start replacing resistors in the low voltage, low signal level locations.
PostPosted: Thu Dec 11, 2008 9:48 am
Just wanted to make sure. I appreciate the quick replies to both of my questions.
P.s. I guess the only real way to cure the hiss is to play louder :wink:
