It is currently Tue Jan 20, 2026 6:19 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sat Jan 17, 2009 11:36 am
Power Transformer
Power is same size as the OT. HV 315-0-315 to 180mA for a little extra beef. 6.3 CT is at 3A
Partridge Design 8K Transformer
OT Specs:
The OT is really close to a Partridge on file that was torn down by Heyboer. It's built how the Partridge was set with the same interleave and hook up. It's a very involved winding with 4 primary sections and 3 secondary sections.
29 guage M-6 laminations that are the same size lams as original.
4-8-16 0hm outputs
Both transformers are the same size. In stand up, it will be tall way up 3 3/4" H X 3 1/8" W and 1 1/2" Plus the brackets, which are about 1/2" out on each side.
Same flying lead colours as our 18 watt OT.
Same flying lead colours as our 18 watt PT.
We also received a simpler version of the OT so we will build another TRIWATT and then compare the two for tone and decide which is best.
PostPosted: Sun Jan 18, 2009 1:58 am
Alrighty then! Just say when!!!!!! :D
Brent Bodrug
Producer-Engineer/Songwriter
www.slyfichapel.com
 Post subject: Speaker Impedence?
PostPosted: Sun Jan 18, 2009 1:07 pm
Will the Output Transformer allow for 4/8/16 Ohm speaker selection?
ROB
 Post subject: Re: Speaker Impedence?
PostPosted: Sun Jan 18, 2009 3:36 pm
Yes, also updated the info above.
PostPosted: Sun Jan 18, 2009 10:14 pm
TRIWATT is up and working with new iron installed in the same locations for production versions. The 4 pre-amp tubes will be moved 2 more inches to the far end, for better pre/power amp separation.
Transformers in Place - Front view
Transformers in Place - Top view
Transformers in Place - Rear view
PostPosted: Sun Jan 18, 2009 11:42 pm
Wow, those are some big chunks of iron :D
Careful moving the pre's too far into that corner, those of us with big paws and right handed have a problem working in that corner :P :P
Waiting for the test reports :D :D :D :D
PostPosted: Mon Jan 19, 2009 12:16 am
I second that! But on the 2 V6's I've built I've mounted one the tag strips for the inputs on the side of the chassis instead of in the corner. Makes it a little easier, but still tight quarters.
And you're right - that's some pretty hefty looking iron - especially the OT! I can't say I have a problem with that!
PostPosted: Mon Jan 19, 2009 7:54 am
Yes they are a good size and weigh in at about 5.25 lb each, 10.5 lb per set! The 18 watt/15 watt are 7 lb per set.
We'll be careful with the layout. At this point I sure dont want to change too much.
PostPosted: Mon Jan 19, 2009 11:14 am
Looks great Stephen! How about a shot of the business section for us wiring guys :D
PostPosted: Mon Jan 19, 2009 12:29 pm
i am quite excited to build this.
really cool.
Any Sound info on these changes ??
Thank you for the upkeep of detailed info.
".....black sabbath....i...i don't even think there was anything before black sabbth...i...i..ummm"
- ozzy.
PostPosted: Mon Jan 19, 2009 12:48 pm
This is the first prototype amp, and the wiring below deck is therefore a little rough, especially after various mods, changes, tweaks, experiments with different grounds, transformers, etc. Stephen has also made some changes to the board, based on what we learned from this prototype. Components are now placed in a more Hiwatt-like rectilinear fashion, and we've optimized their placement for tidier wiring, minimal wire lengths, etc. We're also now using turrets instead of eyelets, there are now two cap cans, and we've altered the position of the power tubes to improve their spacing, relative to the transformers. So there is a gut shot earlier in this thread, but you'll need to bear in mind that the finished product will look somewhat different. :)
Edit: It looks like Stephen just re-posted that gut shot.
The most immediate difference we found was improved range on the Presence control. I'll be testing the amp some more this week, but we'll really need to get some of the guys with golden ears involved for listening tests. :)
PostPosted: Mon Jan 19, 2009 12:50 pm
Inside View - Looks something like this old pic!
Not military style but considering it works, is a protoype, required some wiring changes etc. - not bad.
Neds an update pic with the new iron. We'll save that for #2 perhaps.
PostPosted: Mon Jan 19, 2009 3:19 pm
Looks great for a proto guys. Congratulations and thanks to all involved for sharing this whole process :)
What impact do you think a tube rectifier would have on the sound and feel of this amp? I'm sort of a "sag" fan.
PostPosted: Mon Jan 19, 2009 4:34 pm
IMO it would lose a big part of the Hiwatt vibe. I know where you're coming from though, as I'm a total Marshall 18W fan. But these amps are very different - solid state power supply with 100uF filter caps, fixed bias, hi-fi spec transformers, etc. They have their own kind of tough charm. :)
PostPosted: Mon Jan 19, 2009 6:13 pm
I'm with Phil, I think it would compromise the amp. Hiwatt's are all about urgency - the sag would kill that. It ain't a Marshall, but fear not, it's plenty "tooby"... to me it's like a Marshall that's gone to the gym - a bit more testosterone and piss and vinegar... ;)
My advice to anyone with a conceptual hang-up on this thing is... listen first... then decide whether it's a problem for you or not... :) More clips soon... :D
Brent Bodrug
www.slyfichapel.com
PostPosted: Tue Jan 20, 2009 11:44 pm
Well,I've been playing the amp with the new transformers installed. It sounds GREAT with these big hefty transformers. I've been testing it with my vintage G12H-30 cab, and the tone is very clear and full, with all the chimey cleans and saturated overdrive you could ever want. There is a clarity and evenness in the highs now that I really like. Totally Hiwatt. :D
PS: I also posted this in the other (long) Triwatt thread, just for completeness
PostPosted: Wed Jan 21, 2009 12:02 pm
swwwwwwweeeeeeeeeeeeeet.
that sounds like what i'm looking forward to hearing.
:D
- ozzy.
PostPosted: Wed Jan 21, 2009 2:02 pm
Even though this version uses the less complex Partridge OT, it sounds so good that we want to take it into the bgroup music studio to do some extensive recording with it.
I don't really think Brent will have a problem with that. The problem may be wrestling it out of his clutches afterwards! :D
PostPosted: Wed Jan 21, 2009 3:56 pm
Why do I forsee a "cold dead hands" quote from Brent some time soon? :D
I just can't wait to get my hands on one of these puppies!
PostPosted: Wed Jan 21, 2009 7:34 pm
LOL! Too funny guys... I'll definitely oblige with the "cold dead hands" comment once I have #2 in my clutches! #1 was never mine to start with so it wouldn't really be fair to expect that it should be mine... although I could definitely hold it ransom until #2 is completed!!! :twisted: :twisted: :twisted: :twisted: :wink:
Lots of clips to come... we're working on the day for the handoff and I've already got Rob brushing up on his classic rock repertoire... :)
Brent Bodrug
www.slyfichapel.com
