It is currently Tue Jan 20, 2026 1:17 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jan 28, 2009 1:55 pm
Should have read it a little closer! OOPs! Let's hope there's not a 2 yr wait for the amp.....I am not gettin any younger!!!!!
PostPosted: Wed Jan 28, 2009 4:57 pm
b0b0 wrote:
I'm thinkin' he's saying there's a 2 year wait for a Ric 360.
Yes, that's right.
PostPosted: Wed Jan 28, 2009 7:07 pm
Stoo wrote:
Heh Brent!
How come everytime I read one of your Triwatt posts, I feel like having a cigarette afterwards? :giggle:
Stew
LOL! :lol:
Brent Bodrug
Producer-Engineer/Songwriter
www.slyfichapel.com
PostPosted: Wed Jan 28, 2009 7:11 pm
b0b0 wrote:
G-log wrote:
A 2 year wait? Really?!!
Yes, I was talking about the Ric 360. I ordered mine in the summer of '06 and just got it this past fall... :shock: Worth the wait though... :D
The Triwatt is imminent!!! 8)
Brent Bodrug
www.slyfichapel.com
 Post subject: Transformer Options?
PostPosted: Thu Jan 29, 2009 2:07 pm
Reading thru I see that two options (simple & more complex) transformers are being tested. What are the major differences? (Is there a line level out option on the complex one?)
Also could the power transformer being tested handle a Heyboer 50watt EL34 Hiwatt Transformer, instead of the stock OT, or would it be pushing it to much?
I am pretty sure I would like to go with the stock transformers (for the 6V6 & KT66), but I would like to know if the 50 watt EL34 Transformer is an option. - (I ran into my box of unused EL34 Teslas I bought when they stopped production in the early 90s.)
ROB
PostPosted: Thu Jan 29, 2009 2:44 pm
I think we went around the EL34 horn but , no, the OT for this will best accommodate 6V6 or KT66. Not that the EL34 wont work with it, just not perfectly. The PT should be fine though not as high as some.
There is no line out on this OT, this is a function of the design (which can be easily added later).
PostPosted: Thu Jan 29, 2009 4:57 pm
Sorry for the confusion. I ment that if the stock transformer was swapped out and replaced with something like a Mojo (Heyboer) MOJO785 50W Hiwatt OT, that was design the use EL34 tubes.
ROB
 Post subject: Re: Transformer Options?
PostPosted: Thu Jan 29, 2009 9:55 pm
Yes, the transformers we're testing at the moment have the same mounting hole arrangement as 50W Hiwatt clone iron. However, our PT's voltage is a little on the lowish side for EL34s, so you wouldn't get the usual 50 to 60WMS out.
I think I should clarify a little here. The classic Hiwatt/Partridge OT "line out" is a 100V line output, for driving multiple muzak speakers typically mounted in ceilings. :shock: Somehow, I doubt that would be a lot of interest to you. :)
We've actually been testing out several different varieties of OTs and PTs, to find which are most suitable, some based on the Hiwatt/Partride designs and some not. Price-wise, we have found the law of diminishing returns also very much applies. Surprisingly, the PT has proved the hardest to get right, since you need high voltages to get the signature Hiwatt sound, but you don't want to go so high that the 6V6s get fried. Some of the PTs we tested also delivered rectified DC voltages below spec.
PostPosted: Mon Feb 09, 2009 1:19 pm
Been kind of quiet for a few days :D
What's the ETA for the transformers that you're waiting on now and how are they different from the last set tested? :P :P
Inquiring minds want to know :wink: :wink:
PostPosted: Mon Feb 09, 2009 2:09 pm
Any day now, the Higher Voltage PT should arrive and we expect, that's it. The nthe fun begins!
PostPosted: Mon Feb 09, 2009 6:35 pm
but when does MY fun begin??? Huh? HUH???
AJC
PostPosted: Mon Feb 09, 2009 8:30 pm
Soon, the PTs arrived today.
PostPosted: Mon Feb 09, 2009 10:34 pm
8) 8) 8)
PostPosted: Tue Feb 10, 2009 8:09 am
PT installed. Amp is off to Phils for check-out & then it's Brent's turn.
PostPosted: Tue Feb 10, 2009 9:27 pm
where's that dancing Banana when you need one ??
ahhahahaa........i guess this yellow dot dude will have to suffice.
:D
".....black sabbath....i...i don't even think there was anything before black sabbth...i...i..ummm"
- ozzy.
PostPosted: Tue Feb 10, 2009 9:31 pm
Got to Zaphod's and we cranked it up - a bit. Cleans to die for. Throw in the OD and crunch to die for. 8) Kicked some butt!
It has over 450V on the plates so we have taken TRIWATT up yet another notch.
We think bgroup will be happy. :D I know I was!!
PostPosted: Tue Feb 10, 2009 9:54 pm
Wish I could have gone with you. I thought for a second, I'd be able to sneak in the back way.
Damn family commitments :D
J
PostPosted: Tue Feb 10, 2009 11:34 pm
I've kept quiet reading these threads for the last few months hoping I'd forget about it... Always wanted a Hi(Tri)watt just cuz.
My wife's gonna be pissed! 8)
Deric®
PostPosted: Wed Feb 11, 2009 10:55 am
Is that with 6V6s or KT66s?
A friend of mine loves the first years of old Marshall Plexi 100 Watts. I heard the reason why they sounded better, to some people, was the higher voltages. Cleaner and more like a Hiwatt.
ROB
PostPosted: Wed Feb 11, 2009 11:52 am
That's with the JJ 6V6s. I'm going through a series of tests with the 6V6s, before I test with the KT66s. I absolutely agree with you about the voltage thing. IMO the toughness of the Hiwatt tone depends on high voltages, including around 400V in the preamp and PI. :shock: This is also why a VVR doesn't make a whole lot of sense in this type of amp.
With the higher voltage this amp is sounding the Hiwattish best I've ever heard it! I can already sense Brent salivating. :lol: Not a good thing to do near any high-voltage tube amp! :shock:
