It is currently Tue Jan 20, 2026 11:04 am
PostPosted: Sat Jul 04, 2009 9:12 am
Thanks for the info :D
I have JJ's in there now, waiting for a pair of NOS Sylvania's :D :D
Once I get them in there I'll recheck.
PostPosted: Sat Jul 04, 2009 2:49 pm
You dont need to use 2W in there either. 1W is plenty. To get the higher ma, you could try maybe 200K 1W.
PostPosted: Sat Jul 04, 2009 8:54 pm
Set the dissapation at about 70% with a set of JJ 6v6's, all pre's and PI are Ei 12ax7's. Used the bias switch set for KT66's to get a 21mA bias on the JJ's.
This sucker is LOUD :D No squeel even with the overdrive maxed, but hard to keep feedback in check :D :D
With the overdrive on, getting a fuzz tone, probably because of the 12ax7 in the PI for now, preamp is getting hit pretty hard with the signal from the LP's humbuckers.
Cleans up nice when I roll back the volume on the LP.
Noticeable difference between the three inputs- Nice :P :P
Waiting for the NOS tubes to see what she'll do then :D :D
PostPosted: Sun Jul 05, 2009 9:30 am
Congratulations!!! :thumbsup: :D
BTW your tube selector switch is actually in the 6V6 position. You would get a lot less current with the switch in the KT66 position.
PostPosted: Sun Jul 05, 2009 10:16 am
Thanks for the update and clarification :D
I'll post an update when the NOS tubes go in :!:
Users browsing this forum: Google [Bot] and 30 guests
