It is currently Fri Apr 17, 2026 10:22 pm
PostPosted: Tue Mar 02, 2010 3:38 am
HEHE, Hi all, I'm back. Its been a while but I was led onto the dark trail of CNC. Last amp I built was the sIII I think.
Whats new anything hot that desperately needs to be built?
Hi coco
Having fun making guitars and necks.
heres the machine I built.
http://www.youtube.com/watch?v=FadI53SivOg
and here's my first test cut.
http://www.youtube.com/watch?v=ra4amnO6L8g
PostPosted: Tue Mar 02, 2010 1:38 pm
Geez, more talented people in the forum. What a great place to hang out. :)
PostPosted: Thu Mar 04, 2010 12:30 am
Trinity HiWatt.
Nice CNC! :shock: I wish that I had a bigger pile of spare change. I'd pop for one of those in a heartbeat. I'm guessing that you could buy a small reliable used car for less money.
LeeMo
PostPosted: Thu Mar 04, 2010 1:03 pm
It's awesome! (both CNC & TRIWATT). I thought it would be way cool to cut out cab parts with a CNC.
TRIWATT read a summary about it here: viewtopic.php?t=1516
How do you get all those curve & angle info into the computer?
PostPosted: Thu Mar 04, 2010 1:29 pm
LeeMo wrote:
Trinity HiWatt.
LeeMo
You can buy a brand new, tricked out car for less than an entry level (industrial quality) CNC machining center.
AJC
PostPosted: Thu Mar 04, 2010 4:41 pm
I built this machine from scratch. Cost me in parts $2500.00.
I am doing 3d models of the guitars and necks on the computer. The easy stuff can be with a 2d cad program. or even import a hand drawn sketch and work in the cad. The cabs should be a piece of cake. I built into the machine the capability of the machine to do dovetails quickly. Then you run it through a CAM program to convert to gcode so the machine can cut it out. Once I figure out how to finish the guitars and necks I am going to use it to make my chassis's, faceplates etc... and any other parts I can figure out. I am working on making a brake to bend the chassis's after I cut them on the machine. ITs been a real fun ride so far. I'm doing musicman's, tele's and jazz bass's so far. I just haven't figure out yet or attempted to finish them......:-) The machine is really easy to operate, and the computer stuff is a fun part also.
I'll have to check out the triwats. Is there schematics running around for these units?
PostPosted: Thu Mar 04, 2010 7:28 pm
Triwatt docs are in the "resources" section :D
viewtopic.php?t=1567
Bit more of an involved build than as sIII, but it's a NICE amp :P :P :P
I'd be interested in any details on your CNC center, looks like a fun thing to build and if it can make reproducable necks :D :D :D :D
PostPosted: Fri Mar 05, 2010 7:01 pm
I've made three necks for testing out of maple and they were all within one thousands of an inch.
A few different body's. My fav is obviously the Tele. Working on a model for the thinline now. Only if I could put a kickass finish on them. I am testing this.
http://www.youtube.com/watch?v=JdRD48n_nbg
http://www.youtube.com/watch?v=W-8oIqTyCIM
You can rummage through here and get some pics of the build among other things.
http://www.rbevins.com/CNC/
PostPosted: Fri Mar 05, 2010 7:23 pm
Thanks for the info :D :!:
Looks good for a long term project I'm thinking about :wink:
How much finish work do the pieces need after milling to get all the contours smooth??
What sort of finish are you thinking about? I'm on hold ($) on a tele project of my own, finish is the next step and I have the Stew-Mac finish book, good info!!
PostPosted: Fri Mar 05, 2010 9:30 pm
That bear paw fretboard in the thread is right off the machine/. YOu can see there is not alot of sanding to do. Very light sanding.
Finsih I think I am going to use alimin dye with chip shellac. Not sure yet.
PostPosted: Sat Mar 06, 2010 2:19 pm
I took a look at your picture files, the necks are very close to final shape :shock: Not much clean-up required :D
Very nice job on those :!: :!: Were the fret slots cut with the NC too?
A lot of guys use Tru-oil on their maple necks, easy to use and apply and supposed to do a very nice finish.
Thanks for the information. :D :D
PostPosted: Sun Mar 07, 2010 1:26 am
Yeah, I am going to try tru-oil.
The fret slots were cut with the machine also. a .023 endmill.
