It is currently Mon Apr 07, 2025 1:53 am
PostPosted: Sat May 08, 2010 8:36 am
TRIWATT owner here, and I just got an insane deal on a barely used TC-15, which is now in the mail. I understand the TC-15 is not a channel-switching amp. But can I toggle between the two using an A/B/Y pedal? Anyone doing this? If so, is there a particular A/B/Y pedal you like?
Thanks. Can't wait to try out the TC-15.
PostPosted: Sat May 08, 2010 10:41 pm
I just did in rehearsal last week, it worked perfectly. Two different sounds on tap at the touch of an A/B switch!
PostPosted: Sat May 08, 2010 11:10 pm
Great. What A/B box are you using?
PostPosted: Sun May 09, 2010 5:52 am
just one I built, nothing fancy
PostPosted: Sun May 09, 2010 9:53 am
FYI an A/B/Y box will also allow you to blend both channels for an even bigger range of tones.
PostPosted: Sun May 09, 2010 11:24 am
Cool idea! Would the Y setting act as a boost?
PostPosted: Sun May 09, 2010 11:00 pm
No, just give you a wider palette of tones to play with.
